Optical Cables? Good or bad?
nascarmann
nascarmann Posts: 1,464
I would like any thoughts on the pros and cons of optical cables. Are there much of a difference in one to another? Are they better or worse than coax? Why are they? Do you use them? Why would you not use them?
Thanks! :confused:
Oh, the bottle has been to me, my closes friend, my worse enemy!
  • mantis
    mantis Posts: 17,411
    edited April 2002
    Optical cable's are fine as long as you don't break it.Monstercable makes a perfectly good optical cable.Use it.You don't need to spend anymore, no improvement on any tonal level that I have heard.We carry Reference Transparent optical and Compared to the Monster....No difference, but built quality, just becarfull when running them.
    Coax is about the same as well, Monstercable makes a great coax.Stronger than the optial but no tonal difference.I tested this theory untill I was blue in the face, not just on my gear at home, but on hundered's of different setup's.
    Dan
    Dan
  • juice21
    juice21 Posts: 1,866
    edited April 2002
    theoretically, they are better, or at least have the capacity to be better than coaxial digital cables. i however, have not seen a noticible difference between the two (only looked at monster/ar/other mid-level range cables). i stay away from optical as it is too fragile and damages easily. i also prefer the feel of the coaxial's connection, the optical connection seem's flimsly. spending the $ on coaxial, the cable (in my experience anyway) lasts longer, a better value for the money. that's just my opinion, but hey, that's what you asked for...
  • nascarmann
    edited April 2002
    Yes sir I did and thanks to you both, sounds good. I have optical from the CD and DVD to the receiver and coax to the amps. I have seen where some people thought optical was inferior. I aquired some AR Pro Series to replace them(warlock1), but may not now?
  • Aaron
    Aaron Posts: 1,853
    edited April 2002
    I've heard people say that optical is inferior, because it has some kind of bandwidth limitation. I think the limitation was supposed to be in the optical transmitter, not the cable.
    Aaron
  • gidrah
    gidrah Posts: 3,049
    edited April 2002
    I think (but could be wrong) that you can get a better signal transference with a cheap optical cable than you can a cheap coax. I use opticals for CD, DVD, and CDR/RW. To the CDR/RW I also have Monster(something or other) for analog source recording. I haven't done any direct comparisons between optical and coax. Maybe I should. I have done direct comparisons between optical and MC analog. The difference was substantial. This may be(and wil be) due to the different D/A converters. Let the better decoder do the work and go analog from there.
    Make it Funky! :)
  • rskarvan
    rskarvan Posts: 2,374
    edited April 2002
    Buy Monster optical cable.
    Who cares if it breaks... its guaranteed free-replacement for life.
    Unless, of course, Monsters scare you - the price sometimes scares me.
