Eichmann RCA Bullet Plugs
gwh
gwh Posts: 1,451
edited April 2010 in Electronics
Eichmann RCA Bullet Plugs.
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • unbridled_id
    unbridled_id Posts: 179
    edited August 2005
    This is the response from the fellow at bluejeans cables when I asked him about the merits of the bullet plugs.
    I have soldered bullet plugs onto one pair of cables for a customer who
    specially requested it (we don't carry them; he supplied the plugs). My
    impressions were that (1) the plug is very poorly designed for strain
    relief, (2) there's no way to complete shield coverage around the plug
    because of the plastic outer shell, and (3) the plastic material of which
    the plug is made is far too thin and brittle to be relied on for mechanical
    stability. The electrical theories offered for the plug are incoherent and,
    so far as I can tell, completely nonsensical.
    The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
    Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince.
  • mantis
    mantis Posts: 17,394
    edited August 2005
    there nice but not a must have . They don't suck. I like em but not voting.
    Dan
  • Early B.
    Early B. Posts: 7,900
    edited August 2005
    Question is -- do you find them standard on high end cables?
    As soon as they become generally accepted as the de facto high quality plug due to their "sonic improvement," I'll consider buying them.
    "God grooves with tubes."
  • polkatese
    polkatese Posts: 6,767
    edited August 2005
    It is definitely a NICE to have, imo. Frank at Signal Cable hook me up on one set of Analog 2 that I ordered (a couple of years ago). It gives a cleaner top-end, subtle improvement, nevertheless, I can hear the difference.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2005
    I have found no sonic benefit in anything but a simple RCA connection, to include Toslink and their evil children. I work in Telecom, and while applications vary, fiber is used due to capacity advantages, not quality advantages.
    The audio use of fiber optics is hype...unless you find yourself surrounded by endless interference from FM/AM and Microwave transmissions, as well as one of a kind Electro-Magnetic anomalies. You should probably move, and go to the doctor in that case.
    I prefer locking RCA's but not from a sonic perspective.
    Aside from the HT, Polkfest will have ZERO digital connections and ZERO Eichmann terminations. That was just my plug for Polkfest :D
  • danger boy
    danger boy Posts: 15,722
    edited August 2005
    I tried a pair of those RCA connectors. while i didn't notice any difference in sound quality. I did want to own a pair in my system. and see if maybe over time if I did an A - B compairson. i'd notice anything different.
    I guess the cable quality was what made a slight difference, not the bullet plugs.
    so i don't know how to vote. hype, yes. must have, nope.
    PolkFest 2012, who's going>?
  • unc2701
    unc2701 Posts: 3,587
    edited August 2005
    Hype. I built some cables w/ them and they were a pain in the ****... I'd take the neutrik pro-fi ones any day over those- the Neutriks have great strain relief and make ground first, so you don't get thumps if you're messing around with your gear turned on.
    http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=092-114
    Backburner:Krell KAV-300i
  • ezc
    ezc Posts: 426
    edited August 2005
    The eichmann rca are good ends & do make some improvement, for even better imporvement try the WBT Nextgen rca's. They are similar to the eichmanns but are built better & have a better strain relief & to me are easier to work with. You can also switch out the female rca to the nextgen for a better match between male & female rca.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2005
    >>>2) That plastic is pretty good sheilding as is.<<<
    Plastic is good shielding?
  • WilliamM2
    edited August 2005
    The small bit of wire in the plastic will be exposed to any EMI or RFI. It will be insulated, but not shielded.
  • janmike
    janmike Posts: 6,146
    edited August 2005
    If it works for you, use it.
    Michael ;)
    NORTH of 60°
  • WilliamM2
    edited August 2005
    When the housing is metal, the wire is completely shielded. It doesn't matter if the wire is exposed inside the metal housing. I think you have insulation and shielding confused.
  • gwh
    gwh Posts: 1,451
    edited August 2005
    Lot’s of good info and discussion here guys.
    Thanks,
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • gwh
    gwh Posts: 1,451
    edited August 2005
    Update.
    I scored 4 Signal Cable Analog-2’s with Eichmann Copper plugs off Audiogon.
    Very impressed at how snug the plugs fit on the in/outputs, fit more secure than the standard RCA termination from SC.
    Strain relief doesn’t appear to be an issue with the heat shrink Frank uses.
    Sound wise the clarity and bass seem to have improved somewhat , not sure if I can attribute that to the Eichmanns, or going from Analog-1 to A-2, or both.
    All in all I think it’s going to be a tweak well worth the $ spent.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • danger boy
    edited August 2005
    those SC2's with Eichmann's are pretty remarkable sounding i've found.
    wait till they burn in after a couple weeks. they sound even better.
  • polkatese
    edited April 2010
    Digging up an old thread here, but I just switched to a pair of SC2 Eichmann (from Scoche RCA) and definitely can hear top-end improvement. Bitchin'!
  • fbm211
    fbm211 Posts: 1,488
    edited April 2010
    I would suggest the Xhadow RCAs over the eichmann.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • headrott
    headrott Posts: 5,496
    edited April 2010
    I would suggest some of the Aural Thrills teflon RCA plugs. They are some of the best I have found. Something wierd is going on with their web site though or I would post a link. Here is one talking about the plugs and also a link to some of the stuff he sells on Agon.
    Greg
    http://haoodnla.com/article/lxy092111430y9j01/
    http://cgi.audiogon.com/cgi-bin/auc.pl?cablintr&1272419103
  • Face
    Face Posts: 14,340
    edited April 2010
    Those appear to be gold plated brass, nothing special.
  • headrott
    edited April 2010
    Right Face, those ones are. If you read the description, it says you can upgrade to the teflon plugs. There is no picture of them on the Agon page, unfortunately. I would have linked the web page for Aural Thrills itself, but the web page is down for some reason. I could take a picture of mine if you would like to see them. They are a teflon plug with with a strip of pure copper or pure silver as the conductor built into the teflon plug. They are very good to my ears. And, they have no brass involved.
    Greg
