Setting up 2 Polk EX12 Subs
iLLz
I have a Crunch Drive DS-4002 amp and 2 Polk EX12 12" Subs. The subs are 400 watts max with an RMS of 150W. The amp according to (specs I got online) will push 400W x 2 @ 4 Ohms or 200 RMS x 2 @ 4 ohms. I believe I can also brige it to make it MONO @ 800W.
Now my question is, I hear you get more power out of the amp if you hook it up MONO and hook the speakers in parallel. Is this true? How do I do this. Sorry this is all new to me but I am a very smart individual and any advice is greatly apprciated. I want to hook this up the best way and get the best sound but unfortunately this is the equipment i have to work with. I know its not the best so i figrued you great people here could give me a hand in maximizing the performance out of this setup.
Can I bridge this amp which will make it MONO and Wire in parallel? I heard with 2 4-ohm speakers, that will make a 1-ohm load? Is that true? Or will it be a 2-Ohm load which is what I am hoping.
What is the best way, and if anyome could give me some background and details i would really appreciate it.
Thanks in advance,
iLLz
Thanks in advance,
iLLz
Post edited by iLLz on
Go to the Club Polk main page...
Scroll down.
(You will have better luck in the Car Audio section)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
