I hate civics
exalted512
I've been trying to get some audio into my g/f's 04 civic for about 3 days now and all i have so far is the amp mounted, power wire ran, and the dash torn apart so i can try and take out the damn stock radio. I have never seen anything this bad before. I had to take apart the center console to get the fuggin radio out!! and i still cant get it out. i joined a civic forum (last thing i ever though i would do) to ask some questions. they have a sticky on it but i still cant figure it out. so far ive put a couple small marks on the dash from the screw driver trying to pry it out and broke a gerber knife...
**** civics
-Cody
**** civics
-Cody
Post edited by exalted512 on
try a chainsaw. :eek:PolkFest 2012, who's going>?
damn near had to. me and the girlfriend were able to get it out though. stupid honda
I know exactly what you are talking about. We have a 2000 Civic EX, and if were not for the Crutchfield instructions it would have been more of a pain than it was.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I LOVE my Ram. That thing is so easy to install in.
The dash comes off pretty easy, just a couple littl pop latches and its out. The doors are super simple. 2 screws, and one bolt that holds the door handle on and then you pull it off. One time a terminal end came off my old Momo 6x9's and, while pumping gas, I was able to take the door panel off, pull the speaker out and replace the wire, put the speaker back in and put the door panel on before the tank was full! I love it.
The downside? No freaking room for mounting amps and subs!polkaudio sound quality competitor since 2005
For the most part my Maxima is also pretty easy to take apart. I can take out my stereo and front speakers in no time. The rears are a different story though, they take a little longer, but still alot easier than our Civic.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
cody - i think there is a bolt behind the radio on the civic.
that's how all the ones i've dealt with were... honda's at that.cats.vans.bag... -
yea, theres two. i got it figured out. the radio is in. the speakers are in. the speaker wire is run, the power wire is run. i just need to mount the crossovers and hook up the amp and find the screws for everything and put those back in and ill be done.
i will never own a honda after this experience. they make **** WAYY too complicated. it took me damn near 2 hours to get the power wire through the firewall. the speakers wouldnt fit in the door even though theyre both 6.5s. i had to do some MAJOR cutting...but the girlfriend wont find out about that:)
Hmmm... maybe because I grew up as a honda guy but I've never had problems installing in any honda.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
cody... y-y-y-y-you had to cut?!
omfg you are c-c-c-c-r-azycats.vans.bag... -
Go do an install in a VW or an Audi, you'll love the Civic...
Thom wrote:Go do an install in a VW or an Audi, you'll love the Civic...It's not good, very fundamentally simply not good. - geolemon
my truck:
pop the door handle trim off. tools needed: knife/flathead screw driver
pop the window crank off. tools needed: knife/rag
unsrew arm rest(2 screws). tools needed: drill/screwdriver if drill is not available
arm rest comes off, pop off sail panel, pop off door
civic: pop off sail panel
pop off three different screw covers
unscrew 5ish screws
pop off 1/2 arm rest
pop off other 1/2 arm rest
unscrew
take off door handle
unhook elec locks/windows
pop off door handle
now for radio
my truck
turn ignition on(not the truck), put it in first gear
pop off trim
take out one plug
press 2 levers and radio slides out
civic:
pop off shifter trim panel
pop off other shifter trim panel
unscrew 2 screws
pop off console trim panel
pop off cigarette lighter trim panel
unsrew/ratchet 2 screw-bolts that cannot be reached with a normal screw driver, nor a 3/8" ratchet, nor a deep socket
get 2 ppl
have one person pull the metal brace out from the bottom, have the other pull on the trim(panel popper needed-screwdriver will fug up the vinyl)
take out 4 plugs(not including radio harness)
take out 4 screws...then the radio comes out
i forgot to say that some models require the stock radio to be in the car so that you can use the remote for some reason, luckily this wasnt one of those models
moral of the story...honda is fuggin retarded
5 hondas', zero problems, 1 saturn, 2 million rattles.
I did one on a Nissan 240SX about 10 years ago. It was when they were first coming out with seperate amps for the factory system. I was only installing a head unit for this hot chick I worked for so I didnt connect the remote turn on cause there wasnt an amp or power antenna. Well when I had everything hooked up there was no sound. Everything was working but just no sound. I worked and looked and cussed and pryed for HOURS trying to figure out why it wouldnt work. Then I got smart and reinstalled the factory unit and it worked fine. Thats when I figured out "hey, I wonder if there is a seperate amp?"
Well needless to say I finally got it working but wound up looking like a complete DOLT to this chick. :rolleyes:
That was my first experience with a **** car.
I miss the old "roll eyes" smiley. It was much more sarcastic.polkaudio sound quality competitor since 2005
drummer81 wrote:5 hondas', zero problems, 1 saturn, 2 million rattles.
i have no rattling with my truck and it only takes about a minute to take off. Its still not totally put back together. I got to clean the inside free of all the debris...lol. Then I have to find all the screws and put them back in the door. I should finish it up sunday
finally!!!!!!
everything is installed and done and i must say im really impressed. i picked up the new sr6500s:D
mid range is nothing short of excellent. tweeter is extremely detailed...EXTREMELY detailed. I'm going to see about moving the jumpers over on the crossover to make it a little softer. I'm not sure what its at right now. My only complaint is its a little less midbass than i like, but thats comparing with the mm6s though which are capable of tons of midbass. The door is really flimsy too which could add a great deal to the lack of midbass. But the midbass is still EXCELLENT in sound quality. No comparision to the old mm6s.
If I could change one thing it would be the screws on the inputs/outputs of the crossovers. I'm not sure how to explain this but the little thing on the screw that "clamps" down to the base isnt connected with the screw. So when you unscrew it the "clamp" stays down and you have to kind of fight it so its up when you put the wire in. But thats my only complaint. These things get damn loud and sound excellent doing so. I am very impressed with this new line from polk and am looking forward to hearing the new subs when they come out.
Mark, put down the bottle and step away from the dead body!
TY Swerve.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
^^ +1 ???It's not good, very fundamentally simply not good. - geolemon
Been sipping a little of grandpa's cough medicine there Mark?
Cody-
I noticed the exact same thing. You unscrew the terminals and the flat piece stays down and you cant get it open enough to put the speaker wire in. What Im did was just strip the wire only about 1/4", flatten in and slide it under the head of the screw. It still isnt perfect but eventually Ill go to Radio Shack and get some terminal ends thatll slide right on there.polkaudio sound quality competitor since 2005
Are you guys talking about a clamp style crossover? bleh they are becoming popular and it seems no one knows how to use them. I remember the guy from knukonceptz talking about them not too long ago.cats.vans.bag...
No its the same type of connectors that have been used for years.
Think of the ones that connect to your amp. You unscrew it and the flat piece of metal loosens. You put the speaker wire under that and tighten the screw back. The SR crossovers flat piece of metal stays down when you loosen the screw and is really hard to get it loose.
Damn its kinda hard to explain, especially when I dont know the technical terms for "the shiny flat piece".polkaudio sound quality competitor since 2005
cody got a girlfriend? wow...
if you think the radio in a civic is hard, try finding an internal oil leak on a motor you just assembled and thought everything was 100% perfect. 0 psi at idle, 3 psi at 2500 rpm. not the oil pump, not the bearings (cam nor crank), not the bypass valve in the filter, not the filter, not the viscosity of the oil, not the oil drive mechanism from the distributor, and not the rear galley plugs nor the front galley plugs, nor the "thrust plate" that oils the timing gears/chain.
what's left? i dont friggin know... pulling the motor and considering scrapping it after dumping over 2,000 into it on performance parts.
i now have a 15,000 dollar planter box sitting in my back yard... i'm considering putting flowers in the bed.The Artist formerly known as PoweredByDodge -
Time to run down to your local friendly neighborhood Dodge dealer and pick yourself up a brand spankin' new Ram!polkaudio sound quality competitor since 2005
well, im guessing ur truck isnt burning oil, that would be my last guess... what upgrades did u do?Picking ones nose signifies a strong sense of self discovery
System in the works:
PP 6V6 with 12ax7 pre ~ 20 watts
15" Jensen MOD 8ohm ~ 97db SPL
DiMarzio HS3 and/or Tone Zone S -
thats what you get for trying to fix up a dodge
Yeah, you shouldve got a Chevy. When they get old, they just fall apart all over so theres no hope of rebuilding them.polkaudio sound quality competitor since 2005
keep dreaming, mines turning 200k and the only thing thats been replaced is the alternator(my fault) and the master cylinder. the only thing dodge has ever done right is the cummins. now if only they had a transmission that could handle it...
new venture 5500 and 4500 take a cummins like a champ, but they're both stick shifts so people "dont like" them. the banks turbo 1600 ft lb torque cummins dakota has a stock nv 5500
far as upgrades... none really.
1990 stock block
1987 police heads
stock crank
stock cam
stock lifters
new bearings (Cam and crank)
new distributor
new oil pump
new water pump
new timing set
stock pistons
stock rods
edelbrock performer rpm intake
pace setter shorty headersThe Artist formerly known as PoweredByDodge -
1600 ft-lbs of torque, are you shi... kidding me??It's not good, very fundamentally simply not good. - geolemon
