Analog or Digital connection
BrentMcGhee
BrentMcGhee Posts: 548
I was wondering where i could go to get all the specifications on the DAC's in my cd player and in my receiver. I want to know becasue i need to know wich one is better.
i.e. use a digital cable from cd player to receiver so i am using my receivers DAC or use analog cables from cd player to receiver so i am using my cd players DAC.
Any ideas?
Post edited by BrentMcGhee on
  • Frank Z
    Frank Z Posts: 5,860
    edited July 2005
    Have you tried using Google? Do a search for the DAC's that are in your gear.
  • BrentMcGhee
    edited July 2005
    i have tried that for a while with no luck... The most i can ever find is the how many bits the dac have, but i need to know alot more about them that.
  • PolkThug
    PolkThug Posts: 7,532
    edited July 2005
    What do you have?
  • BrentMcGhee
    edited July 2005
    well there are a few different pieces of equipment that i want to know the dac specs on but i will just stick with the equipment in my rec room for now.
    CD Player: CDP-CX455
    RECEIVER: STR-DA5ES
  • BrentMcGhee
    edited July 2005
    GEEZ.... i realized since both of those products were sony i would call them and they would be able to tell me.... Well as i am typing this i am on the phone with them and this guy does not know anything.
    At first he thought i was asking how to hook the cd player digitally.
    Then he told me i had the option to hook either analog or digital (well duh) and that a digital connection is always better....
    he does not even understand my question i don't think he knows what a dac is or what exaclty your doing when you choose to hook up digitally or by analog
  • bknauss
    bknauss Posts: 1,441
    edited July 2005
    Its a bit unfair to assume that Sony CS will know what parts are in each of their products. Since Sony has so many products, I'm sure they focus more on FAQs than more technical questions.
    Not everyone can be nearly as good as Polk CS :)
    Brian Knauss
    ex-Electrical Engineer for Polk
  • mantis
    mantis Posts: 17,570
    edited July 2005
    I would buy or use if you have em high quality interconnects and digital cable.
    Sit and listen to your favorite music and see what sounds better.
    Both may have the same exact DAC's. it doesn't matter which ones are better but the ones that sound better are the better ones for you.
    Dan
    Dan
  • BrentMcGhee
    edited July 2005
    ain't that the god honest truth!
    Dan
    I have tried that, i spent almost the entire day yesterday going back and fourth with both connections. They are definalty not the same dac but they have to be almost identical. I can tell wich one is wich when i do a blind test with the two of them but to my ears neither one is any better than the other, they just sound different. So since i really dont prefer one over the other i really just wanted the specs on the two so i could see wich one was better on paper and just use that one....
