srs 2.3tls
ternst
ternst Posts: 3
edited July 2005 in Vintage Speakers
hello,this forum is new to me and found it very informative. have a few questions to anyone that can help. my 2.3tls have serial #s L-4358 R-4332 i am using a onkyo txsr701 rec. integra m504 amp. didnt have interconn cables,made some up,sounds great but not at higher volumes. is my amp not big enough to power these? also any idea manufacture date. inside connector panel has stickers that say 7-89. any info/upgades/tech help would be very much appreciated. thanks for listening:D
Post edited by ternst on
  • hoosier21
    hoosier21 Posts: 4,413
    edited July 2005
    What's wrong with them at higher levels? How high are talking here. Pretty good amp, it has meters so you should be able to see if you are running out of amp.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 50,723
    edited July 2005
    Correction Kim, through 1992. Mine are dated May 1992.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2005
    Jesse,
    Are you reading a date sticker from a driver or from the crossover?
    I am wondering if your 2.3TL's have some internal replacement parts that were manufactured after the official end of production.
    F1nut Posts: 50,723
    edited July 2005
    Raife, both.
  • ternst
    ternst Posts: 3
    edited July 2005
    thanks for the replies,found amp problems,repaired,they sound great! was listening to infinity overtures3 they sounded awsome,these even better! the date that i was talking about was on the rear of the interconnect /speaker cable terminal. wish i knew about these speakers years ago. definatley sound great listening to old classic tunes,yes,supertramp,al stewart,pink floyd,etc,etc,etc!!! stuck in the 70,s/80,s what can i say. once again thanks all,will be checking in from time to time,taking in all of your valuable,informative input. happy listening.:D
