large or small
smkngstv
smkngstv Posts: 13
edited March 2002 in Technical/Setup
should i set my rec.setting (onkyo898) to large or small for my rt1000i with powered subs and running the lfe from rec. to psw-650
smoking
Post edited by smkngstv on
  • Aaron
    Aaron Posts: 1,853
    edited March 2002
    Set them to Large.
    Aaron
  • mantis
    mantis Posts: 17,543
    edited March 2002
    The bests way to set up powered tower's,
    set the receiver to Large(as Aaron said)and runjust speaker level to the speaker if you are using a psw650.Biwire the speaker if you can or just replace the jumper's with the same wire that your speaker is using from the receiver to the speaker.
    Dan
    Dan
