Phoenix Gold
ND13
ND13 Posts: 7,601
edited July 2005 in Car Audio & Electronics
Okay guys, I've been out of the car audio scene since the mid 90's and I'm putting together a budget system in my commuter truck, a '95 Chevy 1500 reg cab stepside. I've put in a KW KDC325 head unit, KW 6 1/2 coaxials in the doors, and KW 4x6 coaxials in the rear. I'm getting a good deal on a Phoenix Gold Octane series R5.0:4 amp and a PG Octane series R10D4 dvc sub in a sealed enclosure.
My question is this:
Is PG still as good as they once were?
I know this is there entry level series, but from the specs I've read they should be more than enough for what I'm trying to accomplish, good tight, clean sound.
"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
Post edited by ND13 on
  • AustinKP
    AustinKP Posts: 861
    edited June 2005
    PG Xenon is very good stuff. Octane is still good for the money. They put out their rated power just fine. You should be happy with it.
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I looked at the Xenon series and it would be overkill for what I need. If I were trying to compete again, I would more than likely go back to PPI and JL Audio.
    Thanks for the reply. Will let you know how everything turns out.
    I just talked to the wholesaler again and asked him to get me prices on doing a 2-channel and a monoblock instead of the 4-channel. The octane monoblock I'm interested in is class ab with an 18db low pass and is 2 ohm rated for the dvc. That way will be a little more $$$, but not much. And it will be cleaner since the bass won't have to share a power supply with the mids and highs.
    Edit- Went with the 2 amp scenario and upgraded the sub at the same time:
    PG R5.0:1 Monoblock rated for 2ohm
    PG R2.5:2 2 channel
    PG ZR10D4 dual 2"/4ohm voice coils
    Will have it all in by Wednesday afternoon.
  • Jstas
    Jstas Posts: 14,842
    edited June 2005
    You should be very pleased with the PG stuff. They are a larger company than they were 10-15 years ago but they still put out some good stuff. The Octane is thier entry level series but it's better than most other mid-line models from alot of other companies.
    Expert Moron Extraordinaire
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2005
    Agreed. Phoenix Gold is still very good stuff. I dont like their Xenon stuff mainly because I dont dig regulated amps but still, you will be happy with yours.
  • exalted512
    exalted512 Posts: 10,735
    edited June 2005
    JLs regulated...
    -Cody
  • MacLeod
    edited June 2005
    Originally posted by exalted512
    JLs regulated...
    -Cody
    Only the Slash series is regulated. The E line is not.
    And furthermore, so what?
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Thanks for all the votes of confidence. I believe that I'll be more that happy with the PG gear. I'm glad that I decided to go the 2 amp way with the better sub. I'll need the extra excursion the ZR10D4 has over the R10D, with the sealed enclosure. It outta rock that little reg cab, anyways, huh. I told the guy I'm letting put the amps and sub in to call me when it's time to tune. I don't let anyone tune a system for me. They always seem to eff it up.
    But anyways, I'll let you guys know how everything sounds Wednesday afternoon.
    Noel
  • exalted512
    edited June 2005
    -Cody
  • AustinKP
    AustinKP Posts: 861
    edited June 2005
    -Cody
    :D
    Alpine 9815
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    The install is happening right now. I'm 38 yrs old and I feel like I did when I was 17 while I was putting in my first "real" system. Can't wait to tune it.
    The wholesaler made a mistake and had to let me have the R4.0:2 instead of the R2.5:2 for the same price. Great, mo power.
    I was impressed with the ZR10D4's build quality and weight. Has cool binding post, also.
    Will let ya'll know how it all sounds in a little bit.
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2005
    Awesome, man! Let us know how it sounds!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    This sub "ROCKS", period. I'm still tweaking the whole system, but so far I'm very pleased. The sub is very accurate, with tight, clean SQ.
    More to come, time to go play a little bit more. Gotta break out some reference CDs.
    TTFN
    Noel
  • MacLeod
    edited June 2005
    Just think, it still has to break in! Itll only sound better with time! ;)
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I've gotta get the installer to change his wiring around a little. I can't fade the 4x6s out, he wired them parallel with the fronts and I told him to not run them off the amp, because they're right next to the ears. It makes the soundstage behind me .
  • MacLeod
    edited June 2005
    Ya shoulda gone without the rears to begin with.
    If you ever decide to upgrade your speakers to components I highly recommend ditching the rears and going stictly with fronts and bi-amping them. Much, much better SQ and imaging.
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    Yeah, I know but it's a budget system. I think I'm gonna unhook them for the night/drive home. You'd **** yourself if you knew what I had in the entire system $$$wise.
  • audiobliss
    edited June 2005
    Yeah? Let's try it. lol
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MacLeod
    edited June 2005
    Probably not. Im quite the bargain hunter myself now that my credit is screwed and I have to pay cash!
    Polk MM6 - Retail $350, I paid $160
    Crossfire VR404 - Retail $380, I paid $250
    Crossfire VR302 - Retail $325, I paid $175
    Year end clearances of last year models is a wonderful thing! :D
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I've got a total of $400 out of pocket and every piece is brand new out of the box and that includes installation. God it's good to be a Used Car manager sometimes. Oh , yeah all warrantied, nothing is hot.
    KW KDC 325 HU
    KW 6 1/2 coaxials
    KW 4x6 coaxials
    and ya'll can read the rest above.
    Should I send you some Depends or a new pair of undees?
  • audiobliss
    edited June 2005
    :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
    Can you do my shopping for me?!?!?
    Sweet!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I've decided to go the component route and remove the rears altogether. My installer is going to get with me later today and let me know what he has in stock and what he would have to order. I know that Polk is one of his lines. He also carries MB, KW, Kicker, Alpine, and PG. I'll probably go with Polk, so what reasonably priced 61/2" seperates does Polk have?
  • audiobliss
    edited June 2005
    Awesome! Polk 6 1/2" components up front and no backs!! Sweet!
    Reasonably priced?! Aww.....you had to go and ruin it......:D :p
    The MMC6500 components retail for $350; I'm assuming that's not reasonably priced, lol. If you're willing to look at the db line-up, the db6500 components are only $240.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I think the db series will be ample. I'll see what my discounted price:p will be. They should be the ticket.:D
  • MacLeod
    edited June 2005
    Look into the MMC6500 first. Its a much better speaker with a far superior crossover.
    They are going for $250 on Sounddomain right now so maybe you can get them for that or less. It would be worth the money.
    Speakers are the one thing you dont want to skimp on.
  • ND13
    ND13 Posts: 7,601
    edited June 2005
    I'll get the price on those and if it's feasible they'll be rocking out within a few days.
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    Got the MMC6500's ordered. They should be singing by Wednesday afternoon. The holiday weekend slows everything down. I got a pretty good deal I think, $225 installed. That raises my grand out-of-pocket total to $625. It's gonna be the nicest $625 system around, for not buying anything used or hot and to include installation and warranties. This is gonna be the longest 5 1/2 days I've had to endure for a while. It just drives me crazy to not have everything right. Oh well, I'll be patient. It'll be worth the wait.
  • audiobliss
    edited July 2005
    It will be worth the wait.
    You got that right!!!! $225 installed?!?! Man!! That's ridiculous! That's gonna be the best system for $800!! You're gonna be seriously satisfied with that! Congrats!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    The MMC6500s are being installed as we speak. Can't wait to hear them sing. Will get back when I can listen.
  • ND13
    ND13 Posts: 7,601
    edited July 2005
    I guess if you want something done right you have to do it yourself. The idiot installer has the MMCs running in friggin MONO. I guess I'll have to spend my only day off this week and rewire the whole damn system, correctly and up to my standards. I know he did everything on the cheap for me, but that was because I gave him alot of other work to do at the dealership(dvd video systems, keyless entries, remote starts,etc).
    The funny thing is they still sound great with just the right channel running thru both sides. I noticed it right off when I put my AC/DC "Back in Black" cd and there was something missing from the intro to "Have A Drink On Me".
  • exalted512
    edited July 2005
    sounds like your installer is a winner:D
    my components alone were $587, but considering they retail for more than a grand, i think i got a good deal.
    glad you like everything, the mm6500s are bad ****:cool:
    -Cody
