Proper center channel for R20's?
Deltarider99
Deltarider99 Posts: 1
edited 2005 23 in Troubleshooting
I just upgraded my old Yamaha receiver to an Onkyo Tx-SR503, and am currently running a pair of BIC Venturi V62's and Polk R20's. For home theater, I am leaning towards using my Polks as the front channels. I see that the recommended CC for the R20's is the CSi20, but I can't seem to find that model ANYWHERE on the internet. Is there another center channel that would match with the R20's well?
Or should I just stick with the BIC's as the fronts and get their CC instead? Thanks much in advance!
Post edited by Deltarider99 on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited 2005 23
    Hello,
    Thanks for posting on the Forum. The CSi20 has been discontinued for a year or so, there could be some remaining inventory at your local Polk dealers. If not, you could consider either the CS1 or CS2 which are part of the Monitor series and are current.
    Regards, Ken
