Lsi 9 crossover
grizzly_black
grizzly_black Posts: 8
edited June 2005 in Troubleshooting
I called and left a message about a replacement tweeter for my right channel on my lsi 9, but did some further investigating and found that it is not the tweeter it is the crossover. The tweeter still produces sond when hooked up to the other crossover so my geuss is that it is the crossover. Can I replace the crossover? If so, How much? Unfortunately I bought these from a guy here in Bozeman MT and am not the orriginal buyer so no warrenty. So I will have to buy it because it will not be covered under warrenty. Could you please help me out, Thanks!
Grizz
Post edited by grizzly_black on
  • Eric W
    Eric W Posts: 556
    edited June 2005
    Hi, first (if you havent already done so) please try disconnecting the brass jumpers in the back and running the speaker wire directly to the top terminals.
    Otherwise, the crossovers are available, they are $60 each + tax&shipping (depending on location), part RE3608-1. If you're interested in ordering it please call 1800-377-7655 option 1, with a Visa or MC, 9-6 EST M-F.
    -Eric
    -Polk Audio
  • grizzly_black
    edited June 2005
    Thanks! for the quick reply! I will give you a call when I get the $ together!
    Grizz
