Amp to receiver cables
doug lang
doug lang Posts: 261
Running 5.1 from amp to receiver. Could you recommend a Good quality cable to use for hook up. Thanks Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
  • Skynut
    Skynut Posts: 2,967
    edited June 2005
    I really like my Raymond cables.
    For a 5.1 he lables each cable and has a different cable for the sub.
    Well built and around $20.00 each cable.
    call 1-509-220-1116 for a quote
    Seriously good IMHO.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • aaharvel
    aaharvel Posts: 4,489
    edited June 2005
    radioshack fusion cables- for the money. 75ohm and shielding; good enough for me.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Skynut
    Skynut Posts: 2,967
    edited June 2005
    Don't do it, it's a trick....Raymond, Raymond, Raymond or you'll beeeee sooorrrry:D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • John K.
    John K. Posts: 822
    edited June 2005
    Doug, keep in mind that these are simply analog signals being carried a few feet; as such no specific impedance cable is needed, nor extra-heavy shielding if you take the usual precaution of not running a power cable along with it. You can spend about as much as you want; for example three sets of regular stereo connectors, or two sets of more heavily shielded 75 ohm component cables for around $10. At the other extreme(I hope it's the extreme)you can go with "Mr. Fields" for about $30,000. Any of them will carry out their heavy burden flawlessly.
  • doug lang
    edited June 2005
    Thanks guys for the info. My amp should be here this week, and the cables will be bought. Doug
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
    F1nut Posts: 52,239
    edited June 2005
    Doug,
    The only way to find out what cables will work best for you is to try some different ones with in your budget and telling us what your budget is would help point you in the right direction. We have a Cable Swap Program here that you can join for free, it only costs you for shipping to the next person. Cables can make a big difference, a little difference or none at all. The better your gear the more likely you are to be able to tell those differences.
    John K. thinks his Sony boom box is hi-fi, so unless you feel the same way, you'd do well to ignore his piles of BS.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited June 2005
    I love my Cobalt Cables
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • doug lang
    edited June 2005
    Hey wingnut where did you get your cables, and how much did you spend. Thanks Doug
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • unc2701
    unc2701 Posts: 3,587
    edited June 2005
    www.cobaltcable.com is fairly good... I like Signal Cable & blue jeans cable, too.
    BUYDVI coupon code will get you 15% off at Cobalt right now
    Backburner:Krell KAV-300i
  • Toxis
    Toxis Posts: 5,116
    edited June 2005
    +1
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2005
    I did go to Mr. Fields "NBS Cables" website to check out his $30,000 speaker cables. I assume "NBS" stands for New (or Newer or Newest) Bull ****.:p
    Those of you who appreciate hand crafted cables will be pleased to know that every NBS cable product is "......available only from the factory and is handmade by Mr. Fields and the chief technician".
    If this keeps up, maybe I will go into the custom cable business.;)
  • amulford
    amulford Posts: 5,020
    edited June 2005
    Are you freakin kidding me???? If that JERKOFF can get that kind of money, I AM going into the busness.
    I just looked on the website.....:eek:
  • Skynut
    Skynut Posts: 2,967
    edited June 2005
    Those wires are made with OFC, do you know how hard it is to find OFC?:confused:
    Good luck making those yourself.:D
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
