RM2300 Satellite
paulmichmat
paulmichmat Posts: 1
edited June 2005 in Troubleshooting
Hi,
I have a 2 front satellite speaker, 2 rear stat and 1 center channel and a sub-woofer connected to a Sony amplifier. We rarely ever play them. On night we decided to enjoy the music and turned them up a bit. About 30 minutes later, the sound suddenly went completely and the amplifier was flashing protection.
Do you have any idea what could be wrong? Please help, I paid too much for these for them to go that easily....
Paul
Post edited by paulmichmat on
  • Skynut
    Skynut Posts: 2,967
    edited June 2005
    I had a similar problem with my sony and polk speakers.
    I do not know why either, I replaced the sony.
    I think it may have been to small of speaker wires but I never found out for sure.
    Good luck.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Willow
    Willow Posts: 11,232
    edited June 2005
    my guess is it's the sony, can you borrow a receiver from some one else to see if your polks still work, or another set of speakers to see if your sony still works and if it will do the same with the 2 set of speakers?
  • jcs1015
    jcs1015 Posts: 3
    edited June 2005
    Could it be an impedance problem?
    If those speakers are less than 8 ohm then with 2 pair you will have a total impedance of less than 4 ohm which is generally the minimum. You won't notice any problems at low volume but at high volume you will blow your amp or kick in the overload protection circutry.
    I learned this the hard way back when there wasn't overload protection. :-(
