PSW404 Subwoofer won't power on.
RxMan
RxMan Posts: 3
edited May 2005 in Troubleshooting
I have a PSW404 Subwoofer. I have never had any problems with it or noticed any strange behavior. While watching a movie the other day, I noticed that I wasn't hearing the normal bass sound. I checked my subwoofer and the power light was off. I tried flipping the switch from on/off/auto. I tried another outlet and also tried another cable from my amp to subwoofer. The little power light does not come on nor do I get any sound from it. The subwoofer does generate heat that is felt on the back heat sink (or whatever it is called). I do not have warranty coverage, but would like to try to have it repaired. I did remove the amplifier from the cabinet to check for any obvious signs of damage. I did not notice anything, but I don't really know what I am looking for. Any advice?
Thanks,
Eric
Post edited by RxMan on
  • RxMan
    RxMan Posts: 3
    edited May 2005
    After contacting Polk. I directly connected the woofer with speaker cable and it works fine. I also connected the subwoofer directly to a dvd player with an audio CD. With this I get no audio. I can assume that it is a problem on the amp side. The fuse is not blown. It still generates heat, but no power light.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2005
    You should talk to Ken, in Polk customer service, and see what your repair / replace options are. Not that you can't get good info going back and forth on a thread here - just go straight to the man and git 'er done.
    Welcome to the forum.
    Cheers,
    Russ
  • RxMan
    RxMan Posts: 3
    edited May 2005
    I did contact Ken. He helped me with trouble shooting the problem. A replacement part is needed and has already been taken care of!!
    Awesome customer support!!
