CS350 Magnet Fell Off
Earthy
I posted this over on the speaker forum, but thought this might be a better place for it.
I unpacked my newly aquired CS350 today. It was in imaculate shape, but it appears that during shipping, the glue let go on one of the MW4850 magnets. It was loose in the box. Since the speaker rides face up, I suspect was just from some gorilla UPS handling.
The magnet poped back in place, and I am curious if I should order a replacement, or if there is any chance it will work up to par. Should I try to reglue it, or use it for a paper weight? I have not had a chance to hook it up and see if it even works.
Thanks!
Earthy
Thanks!
Earthy
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808
Post edited by Earthy on
I would order a new one and use the other one to play with.
Contact polk cust. srvs. and see what they say.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
From the sound of it, the video shielding magnet fell off- just epoxy it back on & call it a day (but try to position it as exactly as you can)... if you put it on top of your TV and notice some discoloration, then you didn't get it placed exactly right.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
The magnet in question was around 2.5" in diameter and about 3/4" thick. It had a hole in it, and what looked like a sleeve protruding forward a bit. I could see where the little drizzle of glue was before. The magnet didn't have a lot of room when I put it back, and it's strong enough to make it tricky to gently place. Does that sound like the video shielding magnet?
Thanks for the help!
EarthyPolk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808 -
Yep, that's the bucking magnet and as unc2701 stated, just glue it back on.Political Correctness'.........defined
President of Club Polk -
Well that's the best darn news I've had all day!
Thanks folks!
Parasound Halo A21
Parasound Halo P3
Home theater
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
PC LSiM 703
Home Theater #2
Onkyo TX-NR808
