Subwoofer need advice
danger boy
I'm thinking of either adding a second subwoofer or doing away with my current PSW350 and getting one with a little more punch to it. Any suggestions at the pros and cons of driving two subs with one receiver? secondly, good sub for under $800. Can't go over $800 pesos, period. Looking at HSU Research TN1225HO down to 25Hz.
PolkFest 2012, who's going>?
Post edited by RyanC_Masimo on
i highly recommend the HSU! i currently am running 2 HSU vtf-2's. i haven't heard the TN1225HO, but i will stand behind the vf-2's. IMO, HSU subs are the best for the $$$...
two subs are better than one. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
Right, sell the 350 for a couple of hundred dollars, then buy 2 HSU VTF-2's and enjoy yourself.
you could try sv subwoofers if you want a tube style sub my self am going to buld one all i need is time i am curentley tileing my entry/kitchen and dineing room i have the entyr dune and moveing on
the psw450 is the next step up, but without knowing what you need out of your sub,then it's hard to recommend.I would try the psw650 as well ,bring them home andd test them,see if it work's,Trade your 350 in(if you can).
Good luck!!
DanDan
