Fanfare Acoustics Prelude Bookshelf Speakers
DarqueKnight
DarqueKnight Posts: 6,765
edited November 2011 in Vintage Speakers
These are my favorite "cheap" speakers. I purchased them in 1986 through the company's (Fanfare Acoustics) "direct audition" program. I was quite surprised and impressed by the sound they produced, especially considering the price: $171 inclusive of shipping. These are the only vintage speakers, other than my SDA's, that I have held on to over the years.
I might be one of only a handful of people that actually bought a pair of these speakers as I have never run across a pair on the used market. The company was in business for about five years and then seemingly vanished without a trace. They received several favorable reviews in the Hi-Fi press. I first saw them in an ad in Audio magazine.
The following is taken from a Fanfare brochure:
"THE FANFARE STORY
Founded in 1983 with the goal of building state of the art speakers at reasonable prices, Fanfare has earned an enviable reputation with music lovers, audiophiles and critics. With products offering great value at the retail prices set by conventional distribution through high-end audio retailers, Fanfare is now taking the bold step to offer even better value and service to audiophiles and music lovers. With DIRECT AUDITION the customer enjoys wholesale level pricing, plus the advantage of being able to audition the Fanfare speakers in the actual listening environment where they will be used, including both the room and equipment.
There are two critically acclaimed models in the Fanfare line: the Tempo II and the Prelude. Both speakers feature wrap around black doubleknit grills, with solid oak end caps on the top and bottom. They feature heavy duty gold binding post terminals, European dome tweeters, custom built and designed woofers with polypropylene cones, plus the advantages of minimum diffraction, minimum phase error design. Both models are known for extraordinary imaging, matural balance and high definition.
The Prelude is a two way system with a 19mm dome tweeter and a high linearity 6-1/2" polypropylene woofer. The Prelude offers surprisingly good bass from a compact enclosure. At its retail price of $285 a pair it was called "Superb value" by Hi-Fi Heretic magazine. At its new Direct Audition price of $171 per pair, the Fanfare Prelude invites direct comparison with such small speakers as the Spica TC-50 and the Celestion SL-6 in every aspect except price.
Under the terms of the "Direct Audition" plan, the customer has 30 days from the date of shipment to audition the speakers. If the customer should decide for any reason not to keep the speakers, he (or she) can call the toll-free number and Fanfare will arrange to have UPS pick them up. Once the speakers arrive at the factory in good shape, a full refund will be issued to the customer, paid by company check.
Specifications:
Size: 14-1/2" H x 9-1/2" W x 9-1/2" D
Nominal impedance: 6 ohms
Minimum impedance: 3 ohms
Efficiency: 90 dB/1w/1m
Frequency response: 55 to 22,000 Hz +/- 2 dB
Minimum Power: 20 watts
Weight: 16 pounds
System type: Minimum diffraction two-way, with Thile QB3 bass."
The little black rectangles in front of the speakers are metal badges with the name "Fanfare" engraved on them. Those of you who have been reading me for a while know that I do not like badges of any kind on my speakers.
Post edited by DarqueKnight on
  • DarqueKnight
    edited May 2005
    Closeup of badges, for those who like such things.:)
  • DarqueKnight
    edited May 2005
    I replaced the stock binding posts with Cardas HCBP-S binding posts. The 4.7 uF electrolytic capacitor in the crossover was replaced with a high quality ICW polypropylene film capacitor.
  • DarqueKnight
    edited May 2005
    They do not look so pretty naked. Taking a peek at the drivers is not a trivial task. The cabinets are enclosed in a knit "sock" that is secured by the top and bottom oak end caps. Oak end caps on speaker cabinets were all the rage during the mid 80's to early 90's.
    To access the drivers, the following must be done:
    1. The four wood buttons in the top end cap must be (gently) twisted off with a pair (padded) of pliers.
    2. The four screws under the wood buttons must be removed.
    3. The port tube must be removed.
    4. The binding post plate must be removed, but does not have to be disconnected.
    The tweeter has the following stamped on the back of it:
    "H202 8 ohm 22/86 Made in Norway"
    The woofer has the following stamped on the back of it:
    "Speaker Craft 604 FP62010U-4B"
    The tweeters snap into the cabinet and are held in place with plastic expansion pins and a sticky, tacky glue. Would screws really have added that much to the cost?
    It was nice of them to use rubber surrounds with the woofers. The woofers in each cabinet only had two screws holding them in. I though about adding two more screws, but I was afraid I might mess up some design parameter.:p Since the woofers fit so tightly in the cabinet, maybe the manufacturer thought the two additional screws were not needed.:)
    When I owned a pair of LSi7's, I did a comparison of the Preludes to the LSi's. The Preludes held their own remarkably well against the LSi7's. The Preludes actually beat the LSi7's in bass definition and articulation. The Prelude's bass sounds more like an acoustic suspension design than a bass reflex design. The LSi7's were better in midrange definition and detail and much, much better in treble detail.
    heiney9 Posts: 25,534
    edited May 2005
    All buttoned up they remind me of the look of the Baby Advent's.
    Can't say I've ever heard of them, but I'm sure there are many I've not heard of. I still have my first pair of speaker I ever bought. I bought them with my paper route money. They are from a speaker company called "Atlantis" they were "ATL Atlantis 333" 2-way bookshelf w/ 8" paper woofer and 2" paper tweeter. Nice cabinets and grills. These were circa 1978 and today they are laughably horrible sounding. I had to start somewhere :D
  • DarqueKnight
    edited May 2005
    I owned a pair of Baby Advents when I was in college. I gave them (along with a Kenwood receiver) to my mom right after graduation. They are still in use after 20 years.:cool:
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2005
    Those look neat!
  • Tour2ma
    Tour2ma Posts: 10,177
    edited May 2005
    I thought double knit was more of a 70's thing...
    Never heard of them before.
    Other than the tweeter dome being ****-backwards and being better looking in general, your Fanfares remind me of the small EPI 50's. They were nearly a cube and had an oddly offset tweeter.
    More later,
    Tour...
    Vox Copuli
  • nadams
    nadams Posts: 5,877
    edited May 2005
    Funny you should mention the EPI 50s.... I have a pair :)
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=20599&highlight=epi
    Ludicrous gibs!
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2005
    Remember the "lattice" work grilles on early Sansui and Pioneer speakers?..LOL!!!
  • nadams
    nadams Posts: 5,877
    edited May 2005
    I also have a pair of Radioshack Nova-6 speakers that have said plastic "real wood" lattice for the fronts.
    Ludicrous gibs!
  • Tour2ma
    edited May 2005
    Lattice work... for speakers so powerful you had to cage them.
    More later,
    Tour...
    Vox Copuli
  • DarqueKnight
    edited May 2005
    Here are some Fanfare brochures and reviews:
  • DarqueKnight
    edited May 2005
    I remember those. I'm sure the lattice work was "acoustically transparent".:p
  • Pwoody6
    Pwoody6 Posts: 1
    Fanfares were designed and built by Ken Erickson, who is better known for creating the Nitty Gritty record cleaning machine which is still made and sold. He was a close friend who died way too young. I use a pair of his Fanfare tower speakers at home and love them.
  • inspiredsports
    inspiredsports Posts: 5,502
    It's cool when these ancient threads resurface. I always wonder how they were found. Google?
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    pitdogg2 Posts: 27,410
    Twinduct reported
  • twinduct
    twinduct Posts: 4
    edited February 2017
    Seems this board has some forum **** on here. I would love to quote whatever rule I supposedly broke, but after 20 minutes of searching they are no where to be found.
    As I was trying to say before DarqueKnight I have a pair of Preludes also that I found at a goodwill. The prelude emblems were missing so all I had to go off of was speakercraft which didn't help at all. On a whim I removed the binding posts plate and saw Prelude which brought me to this thread and might I say the ONLY shred of info on what I had.
    Only bought them to flip them, but without this thread I would have been stumped on them.
    The post was removed because it was a post to sell. You must have 100 post to sell here. It is plainly explained in the FS sticky which you went around by posting in this one.
  • twinduct
    twinduct Posts: 4
    well I'll save ourselves both time by not counter arguing that, but it wasn't my intention for it to seem like a "sell post" as you claim. It was for DarqueKnight to know he wasn't alone and that his info helped me identify what I had.
    All good stick around and welcome to club polk. DK's done a ton of great work we all here are gratiful for that fact.
  • twinduct
    twinduct Posts: 4
    Thank you. While I do dabble in flipping stuff (don't most people these days?), I actually am a fan of Polks. I just never have joined a forum for them. Have had whole Rti series setup (love the Rti12's+Csi5+Fxi's), but since have downgraded to just some Rt55i's. Sorry for the off-topic.
  • Welcome to the forum twinduct. I still have my Fanfare Preludes.
  • twinduct
    twinduct Posts: 4
    It seems Hal fried a circuit again. He's stuck on auto raise.
  • lightman1
    lightman1 Posts: 10,797
    la2vegas wrote: »
    Don't mind lightman1, he usually starts the bidding low but he buys nearly half the gear that's offered for sale here.
    As far as everyone being a flipper nowadays, I must have skipped that class. Heck, I must have skipped selling in general. Must've spent my time in buying classes.
    With you on that one, vegas.
    Stick around, twoducks. Good folks around here.
    $14....double down my bid.
    RAY! Talk to me, buddy..
  • I might be persuaded to let my UPGRADED Preludes go for $749.99.
