Where can you get a custom shelf?
mantis
mantis Posts: 17,201
edited March 2024 in Clubhouse Archives
My Tv will not hold my center channel.
I'm lookng for a company(before I talk to a cabnet maker) that makes deep large selves. I would like a maplewood,at least 40 inches wide, and 15 inches deep. Something modern that would work in my livingroom. I assume alot of you saw my pics .
Anyone have any ideas?
Dan
Dan
Post edited by RyanC_Masimo on
  • brettw22
    brettw22 Posts: 7,623
    edited April 2005
    EDIT: NM.....the shelf I was thinking of only holds 11 pounds and was just barely over 10" deep so wouldn't do what you were looking for.
    Is the 15" depth mandatory or are you working some extra in there?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2005
    Dan,
    I bought a wood stainable shelf many years ago to hold a TV, it was the right depth for you, but finding one 40" wide may be a problem.
    Anyway, the one I got was from a local hardware store, sorry cant be of more help.
    RT1
    How about getting Salamander to make you one???
  • mantis
    edited April 2005
    brettw22,
    yeah I need the depth. The center channel has a mini stand or a cradle. It allows the center to be pointed. The center weighs 25.1 lbs and the cradle weighs a few lbs as well. I'm sure the wife will want to put stuff on it.
    reeltrouble1,
    Salamander makes a center shelf to go under the tv, this will put my tv to high. I can also get the extention poles and put the shelf above the tv. This is the way I'm gonna go if I can't find a wall shelf.
    looking on the internet is fustrating.
    Dan
    Dan
    VR3 Posts: 28,775
    edited April 2005
    I could make it...
    Would depend on what you want...
    Plans?
    Not sure what your wanting by your description
    Are you wanting this thing mounted on the wall?
    I could easily make a solid maplewood shelf (EASY)....
    However, your looking at 1-2 weeks for me to do (I will have to get the wood, plane (sp) it down, joint it, glue it all together, plane it again, saw it to size, sand it, route it (to give it a look), then attach the back
    After cost of wood/labor/shipping - it would be cheaper to go local
  • brettw22
    edited April 2005
    I don't know that I could imagine a shelf high enough to shoot sound above and down to your seating position over a tv the size yours is.
    For some reason in my head i'm thinking that thing will be 5-6' or higher so the TV isn't completely blocking the direction of sound.
    Good luck to ya though....If you could live with 10-12" deep, a different type of shelf from IKEA would be GREAT.....it's what I have my left surround on if you look in my system showcase. I just cut the 4' shelf down to 15" sections and bought extra brackets as needed.
  • mantis
    edited April 2005
    Thanks Sid. Thats cool of you to offer.
    brettw22,
    Thanks as well but I need 15 inches due to how big the damn center channel is. The center stand also adds a few inchs.
    I'm thinking I gotta call Salamander back and go with that plan.... Man I wish I had the extra cash to go plasma... then the center could go right on top of the stand and the plasma on the wall.
    Damn,
    Dan
    Dan
  • mrmusicman
    mrmusicman Posts: 303
    edited April 2005
    Mantis,
    I purchaced an "Omni" shelf that sits on top of the tv and works perfect for my csi 40,it was had @ C.C for about $40.00.
    Mike
    Outlaw 990 Processor
    Outlaw 755 Amp
    Denon 2900 dvd-sacd
    Dishnetwork HD-Dvr
    55" Sony LCD RPTV
    Lsi 9-fronts
    Lsic-center
    Rt55i- surrounds
    Velodyne cht-10 sub
    2007 Dodge Quad cab
    Kenwood Excelon KDC-X891
    JL Audio 300/V2
    Polk Audio SR 6500 - Fronts
    Polk Audio DB651 - Rear
    2 -10" Treo Subs
    Interfire IB 2600C sub amp
    Sirius Sat radio
    Ipod connection
  • mrmusicman
    edited April 2005
    Mantis ,
    Here is a pic.
    MIke
    Outlaw 755 Amp
    Denon 2900 dvd-sacd
    Dishnetwork HD-Dvr
    55" Sony LCD RPTV
    Lsi 9-fronts
    Lsic-center
    Rt55i- surrounds
    Velodyne cht-10 sub
    2007 Dodge Quad cab
    JL Audio 300/V2
    2 -10" Treo Subs
    Sirius Sat radio
    Ipod connection
    VR3 Posts: 28,775
    edited April 2005
    Toe in your speakers.
  • mantis
    edited April 2005
    mrmusicman
    We have one as well. It has velcro tabs and screw adjustments. I think it looks ugly. I'm trying to avoid using it. The new tv's suck for this reason. Thanks anyway
    Dan
    Dan
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2005
    Mantis,
    I was surfing Audio Advisor and came across the maple side panels for sale. If you found out what the dimensions are you might be able to use one of them...
    http://www.audioadvisor.com/store/productdetail.asp?sku=DMSALS20PM
  • Grimster74
    Grimster74 Posts: 2,576
    edited April 2005
    It can be easily made with a piece of 3/4" oak plywood and stained in a maple finish. You can special order maple wider then 12" also. If done with plywood, you can always line the edges with a piece of hardwood trim. Most kitchen cabinets are 80% plywood with a solid hardwood front. I make furniture as a hobby so it wouldn't cost that much to do. Would it be possible to post another pic so I have a better idea of what exactly it is you are looking to do. I may have a bunch of solid oak laying around the work shop.
  • madmax
    madmax Posts: 12,434
    edited April 2005
    There was a fellow on here several months ago that made an awesome CD shelf. Sorry I can't remember the name. It covered a complete wall. Certainly a fellow who could professionally make whatever you want. Might want to put a WTB in the flea market or just do searches and find him. There was a thread pertaining to starting a business. Sorry, thats all I can remember.
    madmax
    Vinyl, the final frontier...
  • mantis
    edited April 2005
    tryrrthg,
    I own that stand and they make a center shelf. I would have to custom order the poles for it. It would box in my tv and thats what I tred to get away from when I went Salamander and it seems I'm right back where I started with that idea. It's my last resort but I'm still looking for something custom. I may have to hire a cabnet maker to come over and build me something nice..
    Grimster74,
    man that would be killer. I'll post a pic when I switch computer, there is my laptop
    madmax,
    Thanks man
    Dan
    Dan
  • dorokusai
    dorokusai Posts: 25,577
    edited April 2005
    http://www.btech-usa.com/bt15.html
    You could add downtilt with door stop shoes....cut to desired length, and spray paint them black. I'm sure you don't need but a couple degrees, so they would be small.
  • mantis
    edited April 2005
    dorokusai,
    That may work, it's alittle short but will hold the weight. The center weighs 25 lbs and is 22.5"w x 6.5"h x 12.6"d. I'm gonna call the company and see if that will work.
    Grimster74,
    here is a pic of what I'm working with
    Dan
  • Grimster74
    edited April 2005
    Hey Madmax, you wouldn't be talking about this thread would you?
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=25020
  • dorokusai
    edited April 2005
    It extends up to 11"....I can't imagine you would need more for that size speaker. I'm sure you'll work something out either way, good luck.
