Rebuild Sda-srs Crossovers
zorro
I have SDA-SRS (1st generation) and just found out that POLK no longer stocks the crossovers even though they are listed on this site.
I would like to know if any of you that I have read here that rebuilt your crossovers would be interested in coming to northern Vermont (near STOWE VT) to remove and rebuild mine onsite for a fee including travel.
I also read that some of you have completely replaced all of the electronic bits and pieces of the crossover or modded them for better performance which I might want to have done.
Post edited by zorro on
Here is a thread that outlines the entire upgrade (read the whole thread, a parts list is provided as well as a source for parts.) I'd suggest you find a local hifi shop, or interested electronics hobbyist locally, and have them do it for you. FYI - the parts cost approximately $275 (not including new binding posts.)
With all due respect, what you're proposing would cost you as much as a pair of SRSs - if you could find another pair.
Good luck!
