cables question
warhorst
warhorst Posts: 25
hi, i just got my speakers and would like to know if the monster cables HTIB set is any good?
Any recommendations?....would prefer to get a reasonably priced cables for the front,center, surrounds and sub at less then $100.
I just GOT my POLK.....for Home :p
-HONDA CRV SETUP-
POLK MOMO MM6
POLK DB650
POLK MOMO MM120
ECLIPSE EA3422
ECLIPSE EA2212
Post edited by warhorst on
  • mantis
    mantis Posts: 17,563
    edited March 2005
    Monster cable is a good place to start your wire adventure. They make good quality cables and for a price I find to be solid.
    Go for it.
    Dan
    Dan
  • okiepolkie
    okiepolkie Posts: 2,258
    edited March 2005
    If you do a quick search for moster on this forum, you will see that it is not highly regarded. I won't get into the full details, but it boils down to company practices.
    What speakers did you end up getting? This will play a part in determining quality of wire.
    Also, how far are your speakers from your receiver/amp?
    For most front speakers, including the center, 14 guage wire will usually be sufficient.
    16 guague will usually work for surrounds.
    Take a look at www.partsexpress.com for reasonable prices on decent wire.
    edit: Mantis jumped in while I was typing. I agree that Monster is good quality for the price. I just don't agree with how they do business. That is why I don't recommend them.
    Tschüss
    Zach
  • warhorst
    warhorst Posts: 25
    edited March 2005
    hi, i got a rt600, cs245, fx300i for the speakers and distance to the receiver for front are just like 6 feet away.......for the surrounds maybe they are around 25feet away.
    if so, what cables would you reccomend.
    -HONDA CRV SETUP-
    POLK MOMO MM6
    POLK DB650
    POLK MOMO MM120
    ECLIPSE EA3422
    ECLIPSE EA2212
    VR3 Posts: 29,555
    edited March 2005
    for the surrounds
    go to lowes or HD and pick up some 50 foot rolls of 16 awg, 10 bucks...
    Dont go all out or even TRY to go anywhere with the surrounds
  • warhorst
    warhorst Posts: 25
    edited March 2005
    for those 16awg wires....are they the stranded type instead of a single copper strand?
    -HONDA CRV SETUP-
    POLK MOMO MM6
    POLK DB650
    POLK MOMO MM120
    ECLIPSE EA3422
    ECLIPSE EA2212
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2005
