Bananas or Spades
Maurice
Maurice Posts: 517
edited February 2010 in Speakers
I'm going to upgrade my speaker cables next week with some Signal Shotgun Bi's. Just wondering which termination is best. I've been using bare wire so any advice will help.
Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's
Post edited by Maurice on
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2005
    Spades are probably the most versatile, bananas the most convenient. I personally like bananas on my amp end and spades on my speaker end.
    Why?
    There's very little space behind my rack, so banana's on the amp end are far easier to wrestle with. I like spades on the speakers in case I get a bi-wireable speaker, I can "spade" the bottom connection and then use banana jumpers. (I don't bi-wire).
    It's up to you.
    F1nut Posts: 51,698
    edited March 2005
    I prefer banana's, although it may be a Freudian thing as there's just something satisfying about pushing them in the hole.
  • madmax
    madmax Posts: 12,434
    edited March 2005
    I would never use anything other than bare wire. Good solid connection with no chance of noise.
    madmax
    Vinyl, the final frontier...
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited March 2005
    Bananas provide the ultimate in convenience, if you're switching speakers frequently. I like spades at the amp and bananas at the speakers, but some of my speaker cable is so heavy that I use spades all around to avoid stress on the bananas.
    Enjoy your new cables!
  • unc2701
    unc2701 Posts: 3,587
    edited March 2005
    Banana's are way more convenient, but spades have the most contact area... I'm with steveinaz- spades are a pain behind a rack, so I try to get cables with spades on the speaker end & banana's on the amp end.
    Backburner:Krell KAV-300i
    VR3 Posts: 29,398
    edited March 2005
    I'll let anyone on this borrow my speakers...
    Yall be a Banana plug fan in about 2 seconds...
    Bottom mounted terminals suck...
    Nanners and XLR - 100%
    billbillw Posts: 7,477
    edited March 2005
    I'm all for bananas on both ends. The terminals on my receiver are too close to get spades in, at least not without a struggle. I tried spades on the speakers also, but they were a pain. The terminal nuts never seem to be tight enough and they seem to wiggle loose sometimes. Bananas have plenty of contact area, and if you get the locking type, there is no worry about them coming loose. You can find the generic locking bananas pretty cheap on Ebay, something like $40 for 20 connectors.
  • stam4p5
    stam4p5 Posts: 22
    edited March 2005
    I recently put bananas on both ends of all my speakers. So much more convenient and looks a lot better. I will never go back to spades or bare wires.
    HT: Yamaha HTR-5660, Front-RTi38, Center-CSi40, Rear-RT15i, Rear Center-RT15i, Subs-2x Polk DX12 in custom enclosures, Sub Amp-Harman/Kardon Citation Sixteen
    PC: H/K AVR 65, some DIY bookshelves
    The truck: Pioneer premier head, MTX amps, XM radio, 2 pair 6.5" DX Components, 1 DB 12" sub (the old one)
  • janmike
    janmike Posts: 6,146
    edited March 2005
    Ensure that your amp/receiver can accomodate the spades. My Yamaha AVR would not take spades, so when I order my Signal cables I had Frank terminate one end with spades and the other with bananas. Both work great. Although I think Jesse has a point.
    Michael ;)
    NORTH of 60°
  • pjdami
    pjdami Posts: 1,894
    edited March 2005
    Banana who??
    knock ... knock...:D
  • mantis
    mantis Posts: 17,322
    edited March 2005
    who's there???
    Orange.
    Orange who?
    Orange you glad I didn't say banana....
    Dan
  • polkatese
    polkatese Posts: 6,767
    edited March 2005
    anyone have a high-quality bananas DIY source? (and I meant one that doesn't require hot-shrink sleeve to finish, nor solder. Thanks in advance, guys!
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • unc2701
    edited March 2005
    radio shack usually has the twist lock monster bananas:
    http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=278-2755
    I used them for awhile & had no complaints... apart from the usual monster sucks disclaimer.
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2005
    I use spades for jumpers and bananas for everything else. Its convenient and looks pretty.
    edited March 2005
    I think the hot-shrink is purely optional on most. Here is a source for high-quality bananas at wholesale prices:
    Link
    They have great prices on no-frills speaker cable too.
  • polkatese
    edited March 2005
    Thanks, Guys!
  • 2+2
    2+2 Posts: 546
    edited March 2005
    Polkatese, check out www.ac4l.com as well. I have bought IXOS products from tehm including 2 screw bannanas and have been pleased with them....
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • polkatese
    edited March 2005
    roger that, thanks 2+2!
  • pjdami
    pjdami Posts: 1,894
    edited March 2005
    The IXOS bananas are really really good. The two set screw connection is great. FWIW, these are the same bananas that Acoustic Zen uses for their jumpers (for biwireable speakers). Just not labeled IXOS. I have both and can post a pic if you want.
  • polkatese
    edited March 2005
    thanks for the linky, Paul! I will check it out.
  • polkatese
    edited March 2005
    ok, so I settled for this:
    http://www.onecall.com/ModelSearch.htm?L_TK=777_1_0_263_0_0_0_0_0_0
    My first choice was actually IXOS banana, but always wondering about the BFA Banana (with the funky jagged edge) so thought that this is an opportunity. Build quality seems to be very solid, will get em this Friday, and let you know.
    Thanks for your help!
    EDIT: Sorry, the search linky doesn' work. Check next post...
  • polkatese
    edited March 2005
    here is the pics
  • Toxis
    Toxis Posts: 5,116
    edited March 2005
    +1
  • danger boy
    danger boy Posts: 15,722
    edited March 2005
    what if you have an old amp that can't use bananannnaa plugs or spades? and are not that keen on bare wire?
    PolkFest 2012, who's going>?
  • unc2701
    edited March 2005
    Partsexpress.com, a dremel and a soldering iron should fix that old amp up in no time.
    edited March 2005
    What do you have? Spring clips? If so, use pins. They will work fine.
  • humble_jo
    humble_jo Posts: 1
    I don't know whether you knew this, but bananas are not allowed in Europe.
    Our regulations are quite strict on that matter... loosens to easily and is a potential source of house fires.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    humble_jo wrote: »
    Good to know, but the OP was from SoCal, not Europe. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • mantis
    I like both connections. Spades are very nice and have maxium surface contact but bananas work just as good I think. Spades on a visual factor scores way more points. Especially Kimber Kable postmaster spades.
    Dan
