Surfing the forums, one gets to see many pictures of gear and I've realized that....
Jstas
Jstas Posts: 14,996
edited March 2024 in Clubhouse Archives
...many of you need to invest in some cleaning implements! The dust collections you all have going are astounding! Dust kills electronics man. It hold in heat and can even short out circuit board pathways and other circuits. So I found some stuff that every electronics safe cleaning kit should have.
P6582A.jpghttp://www.cyberguys.com/templates/searchdetail.asp?T1=114+0554&dept=lch40&search=&child=
P6581A.jpghttp://www.cyberguys.com/templates/searchdetail.asp?T1=114+0552&dept=lch40&search=&child=
P5956A.jpghttp://www.cyberguys.com/templates/searchdetail.asp?T1=114+0208&dept=lch40&search=&child=
P5957A.jpghttp://www.cyberguys.com/templates/searchdetail.asp?T1=114+0214&dept=lch40&search=&child=
P4168A.jpghttp://www.cyberguys.com/templates/searchdetail.asp?T1=114+0530&dept=lch40&search=&child=
P5625A.jpghttp://www.cyberguys.com/templates/searchdetail.asp?T1=114+0514&dept=lch40&search=&child=
Ya might wanna thing about getting at least a static free duster and a that CO2 Duster Kit. The static free vac is a good idea and will take the place of the dusters too.
Expert Moron Extraordinaire
  • Willow
    Willow Posts: 11,258
    edited March 2005
    can I use a keyboard co2 duster ? and spray right in the receiver?
  • Jstas
    Jstas Posts: 14,996
    edited March 2005
    I'm sorry, I'm not sure what you are asking?
    If you are asking if you CAN use it or if it is OK, yes is the answer. Just be careful not to knock any parts loose. Computers are much more sensitive to static discharge than any piece of stereo equipment. Cleaning products for computer equipment like what I listed above far exceeds what you need for stereo equipment.
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    Cleaning?! Ha! If I wanted to clean, I never wouldve got married!! :p:D
  • exalted512
    exalted512 Posts: 10,734
    edited March 2005
    i dont care how big you are, $10 said you closed the window out as soon as you posted that:p
    -Cody
  • MacLeod
    edited March 2005
    Hmph!
    She knows who the boss is around here. I dont need to hide things like this. I tell her she needs to clean and she knows to jump to it.
    It was just the other day I told her........shhh, here she comes......Ill finish this later......
  • Willow
    edited March 2005
    Sorry if I wasn't clear I was asking If i get my lazy butt to a shop and buy a can of keyboard Co2 cleaner can I spray that in the vents of my receiver without F%^&%)g things up ?
  • brettw22
    brettw22 Posts: 7,623
    edited March 2005
    I use canned air all the time.......MUCH less expensive than the mini Co2 cartridges.....
    Just don't turn them sideways or upside down so it doesn't freeze the hell out of your internal parts.....
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2005
    I would like to officially nominate JSTAS as head-honcho of the Dust Bunny Patrol.
    Possibly Justin will give him the official moniker!!!
    RT1
    Damm post 777 time to go buy a lottery ticket.
  • Jstas
    Jstas Posts: 14,996
    edited March 2005
    If you just shove the nozzle in your vents, you are going to just blow the dust around. Open the thing up and clean it out so the dust gets blown OUT of teh gear.
    Brett, the "canned air" works great but in addition to the extreme temperatures cause by the chemicals leaving the can, it can leave a residue. I gave the CO2 as an option because it is literally chemical free and has no propellant other than pressurization. The kit is expensive and so are the extra containers but the nice thing is that they are refillable. So the benefit there is that you end up saving money in the long run and there are no chemicals to mess up your system. Plus, your body will metabolize CO2 eventhough it isn't good for you in large doses, your body still uses CO2 and you are less likely to be seriously injured when using it as designed than you are with the "canned air". The propellants in the "canned air" and the "canned air" itself are toxic eventhough it says that it is environmentally safe.
  • Jstas
    Jstas Posts: 14,996
    edited March 2005
    RT1
    I would prefer it if that was NOT done.
    I was given the name of "The Cleaner" at work but not because I'm a neat freak or anything silly like that. I just have a habit of helping other departments pick up thier stuff and leave my work areas, voluntarily or not. See, we have a couple departments here that are very poor space managers. They leave horrendous, unprofessional messes everywhere. Since we all have to support the same user base, we try to be cordial to other groups and let them use our server rooms and staging/storage area spaces. The problem lies in that they tend to over-step thier bounds and make a disaster of areas. It then affects how my group can get our work done. So our manager says that an area needs to be cleaned and since I so dearly LOVE to piss in other's Wheaties, I volunteer. Of course I give the offenders ample notice but they rarely heed my warnings until they happen to saunter past the area and see thier equipment wrapped up and stacked on pallets in the hallway destined for warehouse storage. Then they get angry and the wailing and gnashing of teeth ensues. My replies of "You were warned that this would happen." usually don't go over well either.
  • Willow
    edited March 2005
    Call him French Maid :p:D
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2005
    John - The dust issue bothers me as well....pretty gear, covered in funk......ball scratching funk....wife on rag funk....I have my friends over funk....etc.
    The first thing to do when pieces find their way into my home is to de-lame them and try to let them breathe again. I secretly place a piece of me in every piece of gear I resell....so buyer beware.
    BTW, BUY THIS TT FROM ME!
    VR3 Posts: 29,550
    edited March 2005
    I dust my gear regurally once a week, and about every 6-7 months I take my system down and do extensive dusting...
    dust gatherings really fast in my room though
  • madmax
    madmax Posts: 12,434
    edited March 2005
    The more you clean, blow, wipe, move, dust, straighten or polish the more you futz up equipment. Your equipment leaves you alone, leave it alone!
    madmax
    Vinyl, the final frontier...
  • dorokusai
    edited March 2005
    I wish my wife cleaned the rest of the house so I could concentrate on my gear....but that b*tch is lazy.
    <disclaimer> I mean that in a loving way.
  • Frank Z
    Frank Z Posts: 5,860
    edited March 2005
    Here's my cleaning specialist....
  • danger boy
    danger boy Posts: 15,722
    edited March 2005
    it's a good idea to dust on a regular basis that's for sure. but like someone mentioned. dust here collects again fast as I can wipe it away.
    I did some dusting this weekend when I swapped amps.. and within 24 hours. i could see dust collecting again.
    but your point is well taken. dust could start a fire and then you'd be really screwed.
    PolkFest 2012, who's going>?
  • Jstas
    Jstas Posts: 14,996
    edited March 2005
    OK, dust collects quickly on electronics because of EM fields. That is a given and virtually impossible to combat because the EM fields come from not only the power running through system but from the physical movement of motors and such. There will ALWAYS be a thin layer of dust on the components.
    The problem arises when dust starts clogging up the vent holes and caking up on printed circuitboards and processors. It gets clogged into connection ports and renders heatsinks inoperative because it covers the heat dissapation surfaces and reduces the efficiency drastically. Not only can it cause fires but it can cause clipping due to overheating.
    As far as cleaning your stuff, no, it doesn't have to be done daily but if you are cleaning a room, it doesn't hurt to clean the audio equipment with it. Besides, I have seen the plastics and brushed metal surfaces of the finishes get far more damage from body oils and other gunk that are left to sit and corrode the surfaces for far too long than any soft rag or feather duster.
    F1nut Posts: 52,008
    edited March 2005
    I second the motion!
  • reeltrouble1
    edited March 2005
    Well, I still feel Dust Bunny Patrol is accurate, however, since you dont like Cleaner either, then how about "The Organizer"
    This ones for you dude, clean your heart out!!!!!!!!!!!!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2005
    One word......
    :eek:
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • brettw22
    edited March 2005
    Originally posted by disneyjoe7
    One word......
    :eek:
    Look, I'm all for goin ganzo-speak on y'all, but ' :eek: ' is NOT a word..... ;)
  • mantis
    mantis Posts: 17,563
    edited March 2005
    I gotta agree with this along with WIRE MANAGEMENT !!!!!!!!!!!!
    Man I never seen such nice gear killed with dust and wire everywhere.
    My gear is always clean and wire managed.... I take alot of pride in that. I guess most of you people don't give a rats ****. It's all cool if you don't but man do you look at your own pics?????
    WAaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    Dan
    Dan
  • disneyjoe7
    edited March 2005
    LOL, but you get the point :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
