6.75 Components, no sound in tweeters
Anuszewski
Anuszewski Posts: 3
edited March 2005 in Troubleshooting
I just installed a new sound system in my car. It consists of:
Clarion 935VD head unit
Polk 400.4 Amp
Polk DB6750 Component Setup
Polk DB570 Coaxials
2 Polk DB104
Polk 500 Amp
here's the Problem. I setup the 400 amp with the components and the coax just like the manual said to. I put the compnents to the front channel on the amp and the Coax's to the rear channel. The manual says to have the front settings at the following:
24db slope, just about 50hz on freq, HP filter. With those settings, the woofers inthe components don't get any lows. So if you put the filter to off, it sounds great. But I get nothing out of the tweeters (neither left nor right) no matter what I do. I've checked the wires, even swapped the wires (tweeters to crossover) and still nothing. Any ideas? I've adjust the frequency but that does nothing. I've tried pushing the Pre-EQ bypass on and off and still no tweeters. Thanks!
Go Gators!
Jimmy
    F1nut Posts: 50,561
    edited March 2005
    Try posting your question in the On The Move section......down below.
