what causes a sub amp to shut down?
faster100
LOL, No not my dear SVS thank goodness...
I picked up a 10" KLH sub at the flea market this weekend, in "works great" condition according to the seller... It does work, but when i increase sub plate amp volume or pre/receiver volume it makes a noise in the woofer(low sound) and cuts off... I can flip it to off and back on and it comes right back on, unless the volume is still high...
what i did do first, cleaned the volume and x-over pots with cleaner, retouched several solder connections on the larger parts to make sure it wasnt cold solder joints.. checked to see that the woofer wasnt blown,
any idea's... its in good shape and i hate to just toss it.. nor spend 100 to fix it with a new plate amp
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
any idea's ?MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
You're sending too much current to the woofer (possibly from clipping). This probably does one of a couple things:
-there's a thermal protection circuit that turns on and shuts down the amp
-there's an overcurrent protection circuit that shuts down the ampBrian Knauss
ex-Electrical Engineer for Polk -
More later,
Tour...
Vox Copuli
blown sub ??? causing a dead short which would cuase the amp to shut offSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
i already e-mailed KLH, But thanks.... will call shortly if they don't e-mail back,
the woofer works at low volumes, its not blown... Its not getting hot after 15 seconds of use.... Its from a cold start. I just got it 2 days ago so i havent spent alot of time with it. I picked it up dirt cheap and wanted to fix it if it was cheap...
Its not a great loss if its unfixable, and a cheap sub when it was new, kinda a project... got no money in it hardly and would make a cool second room sub.. or my brother in-law also needs a sub... so it will most likely just go to him if i fix it....MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
