Good deal? 4c 16awg monster cable on sale @ parts express
Dannieboiz
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Onkyo TX-SR875
Velodyne DPS-12
Post edited by Dannieboiz on
I don't think you'll find many people around here praising Monster products, just doa search and see what you come up with:D
That being said, this would probably be fine for wiring surround speakers, but I usually use 2 ga for the front stage... -
Also, if you're looking for a 150' spool of wire, this is probably a really good deal.
A crappy 18 ga will cost you at least that much...so yeah, it would be a good investment for wiring surround speakers... -
this is probably a noob question, but what does the 4-cond and the cl-3 mean?
The 4 cond means there are four individual strands of speaker wire wrapped in a jacket(usually shielded).
If you are biamping or biwiring speakers, then this is economical because it is usually a little cheaper than individual strands(or paired strands). Also, it makes it look a little "prettier".
I don't know for sure(and someone correct me if I'm wrong), but I think the CL3 means that it is code sufficient to put it in the wall.
For the price, this isn't bad stuff, even if it does have that brand stamped on it.Tschüss
Zach -
Yep, I think it has to do with burn rate that makes it "safe" for in-wall applications. -
If you're talking about your fronts, personally I've found the lower the gauge the better. Why limit your system with 16 ga wire. If you want to bi-wire the Canare
4S11 at 4x14awg is 100 times better for around .80 cents a foot and even that won't make those speakers shine. Try some 6-8awg with some quality jumpers and it'll blow that stuff away. The low strand count cable is the best sound I've found, the ones with the big, fat conductors.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
They've been auctioning that item for months.
Here's one of their auction's ended on January 31st for $71
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5746693321
Now go check their website, and enter the same part number 109-648
$49.20 at their website.
Their making steady profit on these auctions
