Help! Psw250...no Green Light
snewhouse
snewhouse Posts: 6
edited February 2005 in Troubleshooting
This may be a stupid question, but want to see if I have any options...or not. I've had this PSW250 sub for the past couple of years...worked fine until I decided to move it from one location to the other. Plugged it in and no green light. Tried different outlets that I know work, still no green light, no sound, nada. Please tell me there is a fix or is the amp fried?
Much appreciated for any help.
Post edited by snewhouse on
  • Willow
    Willow Posts: 11,074
    edited January 2005
    Welcome,
    Is it turned on? I know it may sound dumb, Not sure if that sub has a fuse but if yest it may be burnt
  • snewhouse
    snewhouse Posts: 6
    edited January 2005
    Yes, it is turned on...made sure of that. I would think it could be a fuse issue, but do you have any idea if that is something I'd be able to purchase, fix myself? And if so where could I get a fuse?
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    Email or call Ken at Polk customer service. He is very helpful, as are the other representatives and will be able to tell you what you need to do. Much of the time, you will be able to do the work yourself. I've got a PSW250 as well, but I haven't taken it apart yet to see what the inside looks like.
    Tschüss
    Zach
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited January 2005
    Hello,
    Yes, there is a fairly easy way to check the internal AC fuse. First remove the AC power cord from the wall outlet and take out the 12 Phillips head screws that go around the circumference of the backplate. The metal input plate will come away from the cabinet and look at the area where the AC power cord comes through the metal plate. You should find a 1.0 Ampere, 250 Volt time delay fuse that 5mm x 20 mm is size.
    Regards, Ken
  • snewhouse
    snewhouse Posts: 6
    edited January 2005
    Thanks for the reply,
    I took the fuse out last night thinking that may be the problem. I'll have to find a place today to get a replacement to see if that is the problem. Hope it works.
  • Willow
    edited January 2005
  • snewhouse
    snewhouse Posts: 6
    edited January 2005
    Well, got the fuse, but no power. I got several fuses and none of them worked. Any other suggestions much appreciated.
  • snewhouse
    snewhouse Posts: 6
    Does it matter whether the fuse is labeled slow blow or not? I noticed that there several different 1.0 amp 250v fuses. I got a fast acting type. I also notice the original had TSA 1.0 labeled on it. I didn't know if it would be that specific or not.
    Thanks for all the help...
  • [Deleted User]
    Hello,
    It would need to be a "time delay" or "slow blow" type fuse to prevent blowing from the inrush current that happens when the unit is turned on.
    Ken
  • snewhouse
    snewhouse Posts: 6
    Thanks for the response,
    Unfortunately I tried the slow blow type fuse last night with no green light, power, response, etc. I just can't imagine what could of happened. I guess I may just have to buck up and purchase a new sub.
  • [Deleted User]
    Hello,
    It would be a good idea to contact me either via email at kswauger@polkaudio.com or via telephone at 1-800-377-7655 extension 891. I'm sure I can be of help.
    Ken
  • beardog03
    beardog03 Posts: 5,550
    I love this place...
    POLK ROCKS !!
    Not only does one learn alot...
    Polk is there to help when you need it..
    Gotta love it...:D :cool:
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
