K. Swauger - Specs for Monitor 10A or B
waylyn5945
waylyn5945 Posts: 18
edited January 2006 in Troubleshooting
I have a set of Monitor 10s that I would like the specs for but I don't know if they are As or Bs. The tweeter is brushed aluminum with "Polk Audio" stamped at the bottome. I hope you can help me. Thanks.:confused:
Wayno
Post edited by waylyn5945 on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited January 2005
    From your description, it sounds like you have Monitor 10s with SL1000 tweeters. The next step in determining the exact model number is to check the drivers:
    MON 10B(84 & 85) SL1000 tweeter, 2x MW6501 drivers
    MON 10 & 10A SL1000 tweeter, 2x MW6500 drivers
    Link to posted specs for Monitor 10B click here
    Link to thread where Ken talks about 10A specs click here
  • waylyn5945
    edited January 2005
    Thanks BlueMDPicker
    Wayno
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2005
    waylyn,
    As said in another thread, Ken will send you a copy of the manual.
    Here's the contact info...
    http://clubpolk.polkaudio.com/service/contactus.php3
    More later,
    Tour...
    Vox Copuli
  • fermatsEnigma
    fermatsEnigma Posts: 1
    edited January 2006
    hi guys,
    i'm new to this forum (new, new). i found the link thru a google on the monitor 10a.
    here's my interest:
    i'd like to build a subwoofer. not thunderous, but clean. to integrate with ceiling speakers in a 7.1 home theater setup. the ceiling speakers use a 6.5" woofer and 0.5" in-line tweeter (a Parts Express item). the sound is coherent and pleasant, and i didn't have to sell the car to pay for it. and it can get quite loud.
    i'd like to build around the monitor 10a. perhaps add a second 10a.
    i have 1 to experiment with. i like the speed afforded by the dual 6.5" woofers. i would re-build the boxes for greater mechanical stability, and use the behringer 'feedback destroyer' to shape the response -- i think i saw that it should work well with just about anything. i am pursuing this to get my feet wet with box design models, passive radiators, and i always liked the Audio-Pro ACE-BASS concept but could never aford it.
    so some questions:
    1. anyone have real specs on the monitor 10a?
    2. anyone have a real 'review' of the 10a performance? spl? frequency response?
    3. does the polk engineer who created this still survive? would he be likely to provide some insight?
    4. anybody measure the ts-parameters for the 6.5" woofers? or have mechanical specs on the passive radiator?
    and finally,
    5. what's the gut reaction? wasting my time? (i am looking at this as a learning experience. there are probably easier ways to get a subwoofer -- but then i wouldn't have learned anything as a hobbyist)
    thanks, fermatsEnigma
  • joelll
    joelll Posts: 120
    edited January 2006
    Ah, so you have an orphan M10a to experiment on... :)
    Polk actually built something a little like what you're describing, a non-powered subwoofer named LF-14 that used the cabinet of a Monitor 10, with two 6.5-inch midbass drivers and a 12" passive radiator. They show up on fleaBay and on various audio sales sites from time to time, usually under $120.
  • Tour2ma
    edited January 2006
    Lf-14
    More later,
    Tour...
    Vox Copuli
