Bi-Wireable speaker wire.
BakedWafer
BakedWafer Posts: 48
edited January 2005 in Speakers
I have a pair of B+W 803's running to a McIntosh 7205, I am quickly getting home theater pieces and putting together a decent home theater, I am already closing in on my budget of 10,000 but I still need 805 rears. I am not looking to pay an arm and leg for some wire. I just need good quality biwireable speaker wire. Any ideas?
Thanks guys
Post edited by BakedWafer on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2005
    Easy, just don't bother doing it.
    Worry about that crap later, just get up and running.
    If you must, go with www.signalcable.com, it's just a suggestion.
  • mantis
    mantis Posts: 17,419
    edited January 2005
    I just don't get it, if you have Mac and B&W what wouldn't you want to have very high quality speaker wire??
    I have alot of experience with B&W and some with McIntosh. Those 2 together sound Incredible. I suggest you look into Transparent MusicWave Plus non bi wires with replacement jumpers or Musicwave Plus Bi wires. Or Kimber Kable Monocole X with replacement jumbers or Kimber Bifocals X bi wires.
    Wire is every bit as Important to your overall sound as the speakers and amp are. Without good wire between them , I feel you don't get to hear what they can do together.
    Don't cheap out of the wire.
    Dan
    Dan
  • dorokusai
    edited January 2005
    My comment was directed at Bi-Wiring, not wiring as a whole....who gives a **** about Bi-Wire.
  • mantis
    edited January 2005
    This dude does. B&W's are bi wireable. But you can as you know buy a single run with the same quality jumpers.
    I perfer to Bi wire but you can single with jumpers.
    Dan
  • BakedWafer
    edited January 2005
    Dan
    Mantis, I've spent my budget for the time being, I know wire is important and I am working on getting everything together. My plasma arrives tomorrow also! :)
  • dorokusai
    edited January 2005
    Baked - This forum sometimes doesn't know when to stop suggesting that you spend more money. Good luck with what you choose.
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2005
    this hobbie doesnt either
  • BakedWafer
    edited January 2005
    Indeed it doesn't. I am thinking of the monster M series speaker wire (biwireable)
  • dragon1952
    dragon1952 Posts: 4,907
    edited January 2005
    Canare 4S11 is a great value....about 80 cents a foot.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2005
    Nevermind.
    F1nut Posts: 51,787
    edited January 2005
    I'll mind.
    Why ruin a good set up with M cable? There are so many better choices.
  • TroyD
    TroyD Posts: 13,124
    edited January 2005
    What F1 said......
    Eff Monster and thier underhanded business tactics.
    BDT
