Powering the LSi9's...Poll
Toxis
Toxis Posts: 5,116
edited January 2005 in Electronics
Thought I'd throw out a poll to see what you guys would do. I noticed that the LSi9's show the amplifier rating should be between 20-200w. I was originally going to go with the Sunfire Ultimate Receiver (getting an insane price on a demo unit and it's damned sexy ;) ), but that would put 400w/ch at 4 ohms. So, would you go ahead and run that knowing that 400w of clean power shouldn't do any damage (but I do listen to pretty high volumes!) or would you go with say a Denon 3805 to use as a pre/pro and get a multi channel amp to run the speakers. For now, I'm only going to run a 3.1 system because I don't have placement potential for rears/sides but hopefully come summer time, I'll be in a new place that DOES allow 5.1/7.1. So... Sunfire vs. Denon + amp. If you choose the Denon/amp combo, what would you do for amps? Outlaw 200 mono's for the three and worry about the other 2-4 channels when I actually need them or go ahead and find a 5-7ch. amp that'll be well worth it? I really couldn't go much over 800-1000 for a seperate amp, that'd be the only catch. Let's see what everyone says. Also, if you suggest the amp setup, what do you recommend and why?
Post edited by Toxis on
  • mantis
    mantis Posts: 17,321
    edited January 2005
    Also check out Rotel rsx1068 and rsx1056. Both well under the asking price of the Sunfire and they both sound incredible.
    B&K also makes one hell of a receiver that would drive your speakers extremely well. I use B&K myself and love the way it sounds.
    Good luck I voted for the Sunfire. The avr3805 can and will drive them fine But I don't care for the way it sounds. I'm also not a fan of buying a receiver to be a preamp. If you want seperates then buy the matching preamp to the amps.
    Dan
    Dan
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2005
    For the kind of money your looking at spending I'd dump the receiver option and get seperates. Look at it this way, paying full price for a receiver and only using half of it's capabilities is a waste of money that could be used elsewhere in your system.
    Before you finalize your system, checkout the Outlaw 950/7100 combo. 30 day money back no questions asked return policy makes it a smart move.
  • Toxis
    Toxis Posts: 5,116
    edited January 2005
    Well, I can get the Sunfire at an amazing price so that's why I'm looking into it as a receiver of choice. Otherwise, I wouldn't spend that much on just a receiver. But I need a pre/pro that does comp. video switching and has 3 in, 1 out. Upconvergence is a huge + as well but definitely not needed. I'll just tell the g/f that we can't use her VCR on that TV. Darn. :p
    I see what you're saying but I work for a retailer of Denon so I can get the 3805 at a great price, as well as the Sunfire.
    I'm open to used amps off the 'Gon if anyone knows of any!
  • McLoki
    McLoki Posts: 5,231
    edited January 2005
    If you can get the carver for less than the price of a decent pre (or the 3805) and a 5 channel amp, I would say go for it.
    I am running my lsi-7's (and lsiC)with 500 watts and have not had any problems.
    Michael
  • Shizelbs
    Shizelbs Posts: 7,433
    edited January 2005
    Buy the Sunfire, sell it to me, proceed with the Denon + amp. :D
  • Kevinvb11
    Kevinvb11 Posts: 105
    edited January 2005
    I'm pretty sure the Sunfire would equal most decent pre-pro's. Offer me a Sunfire vs Denon 580x, and I'll take the Carver product as it is more focused on sound than bells and whistles.
    I might think that the Sunfire reciever is atleast as good as most pre-pro's out there and I wouldn't hesitate to try one out. I will voice out and say the sunfire the best reciever out there.
    KVB
