Blown Tweeters?
patchsassy
I just got a set of R50's and no sound is coming out of either tweeter. I think I blew them. Is there a fuse or reset? The other two speakers are working... If I did blow them, where can I buy new or better than new ones?
Thanks alot
Mike
Thanks alot
Mike
Post edited by patchsassy on
patchsassy,
Not sure if the R50's are fused. Check them with an Ohm meter to see if their shorted. If their not shorted you can check the tweeters by removing them from the cabinet and connecting your speaker wires directly to the tweeter. That way youll be able to tell if its the tweeters or something else. Just make sure you drive them at a low listening level. If they are blow you can order them directly from Polk, just call the toll free# and they'll hook you right up. Mention you a Polk club member and you'll even get a discout.
O -
Do those have dual binding posts? IE two sets of posts on the back? If so make sure the jumpers are installed.If you will it, dude, it is no dream.
Thanks to both of you for your time and effort. I don't have the double binding posts and I hooked them up directly , after checking for shorts, and got nothing. I suppose I'll be buying new ones and lesson learned here.
Thanks again,
Mike
