revised tweeter's for cs400i
re510
i read a listing on ebay and the guy has a cs400i that has a new revised tri-laminate tweeter from polk is this true and how do you get this so-called revised tweeter?
System:
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Toshiba 51h83 HDTV
Yamaha HTR-5660
Carver AV-405
Pioneer DV-578A-S
Comcast HD cable
RT1000i's
RT35i's
CS400i
F/X300i's
SVS PCi 20-39
Post edited by re510 on
Contact Ken Swauger at Polk, ask him those questions for the straight answer.Political Correctness'.........defined
President of Club Polk -
There is no revision.
There is a slight change between the CS400 tweeter and the CS400i.
Polk stopped making the original Tri-Lam and now are sending out the Silk from the line after it for it's replacement. To me, this is a down-grade and if it is indeed using the Silk - I would stay away from it.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hey Sid,
Just curious... why do you consider the silk tweeter a downgrade from the Tri-lam?
I always thought the reverse was true.
- Ron -
Edited - Nothing to See Here- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Come on trey, everyone knows you are totally biased when it comes to certain models of anything.
To say the rti70 is horrible is outlandish.. and yes i too have listened to the first RT line.. rt55i, cs245i, and alot of the rti line.. I like both, but don't think it was much different from each other.. Now i'll bet polks first runs were better in some respects, a bookshelf compared to a tower is apples and oranges..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
BS?
totally different, larger cabinet.. in some cases larger drivers, the tweeter is higher even if the bookshelf was on a stand in most cases... UMM its always been apparent you hated the RTI line but the constant, RTI is crap, RT rein supreme crap is opinion only... not facts, and tireing
That's all.. I'm not gonna fight about it..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Originally posted by Vr3MxStyler2k3
How in gods name is a tower vs bookshelf apples and oranges?
I mean really - thats BS.
Ultimately, you're comparing the same thing, sound quality...but towers and bookshelves DO have different characteristics, so a direct comparison is a bit odd (i.e. we know that a tower should have more bass, that's just a given) -
Edited - Nothing to See here- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Personally, I don't agree with Sids assessment of the RTi series, but it really doesn't matter.
The comparison he did were on HIS equipment in HIS room, so his findings are just as valid as mine.
I personally love the RTi series, I own the 70s and prefer their sound to anything else I've heard, but that's in my room with my equipment...
It's all just opinion.....
I do agree that the constant (or at least perceived constant) bashing ot the RTi series does get a bit old. Sid, you're entitled to your opinion, and it's just as valid as mine, but you could state your findings with a bit more tact. Saying things like this or that is horrible or terrible is just going to offend people...how about something like "I prefer this to that"...something along those lines...
my $.02 -
I'm done in this one.
I dont like the silk.
RT line needs to be retired.
Yada yada yada.
RT8 is on da da way! Gonna get my Polk on.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey,
why edit everything out, everytime someone disagree's with ya... i agree with maniacs statements...
you don't like them, fine.. But i love mine also.. and out of all the models i like the Rti's as well.. shoot, i have a set of Rti38's set aside boxed in case i ever need/want them and by then they will be long gone from the used market..
alittle more tact is needed when someone really needs a honest unbiased opinion, and may not have the knowledge that even you have... your negative opinion could sway someone new away from a great speaker pair..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Biased from what?
I had 3 pairs of speakers in here of the same series, in different revisions.
My 'biased' opinion came from long listening test and tweaking to see which one I liked.
I stopped talking about the RT line a LONG time ago - I rarely talk about it anymore - but he asked. I answered.
RT8 on da da way.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I think the most important of all your twaks involved a 50 gallon drum of Armour All....No;)
HBomb***WAREMTAE*** -
Hey, I try right?
My favorite tweak had to be the stacking...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
