Woofer rub?
dschnelz
I purchased a used set of RTi28s. One of the woofers has a buzzing sound. I took the woofer out and examined it, and determined that the buzzing goes away when I gently press on the cone in specific areas. Possible causes seem to include:
- The voice coil may be rubbing against the inside of the magnet, possibly due the cone being uncentered in the frame.
- The voice coil may be loose from the cone assembly.
- Crud of some sort stuck inside.
Any ideas? Is there any fix for this short of replacing the woofer?
Post edited by dschnelz on
Seems like it's a voice coil problem, buy a new one and be done with it.Political Correctness'.........defined
President of Club Polk -
Let me know what the woofer part number is. I might have one i can send you. I have a spare one left from a pair of rt25s. if it is the same you are welcome to it.
oops I forgot it isnt the same the woofer in your rti28s is blue mine is black.it came from some rt25s not i s
