center channel
raidical
I have purchased the new Polk monitor 60 series speakers (I love them!) and also the Polk center channel CSI3. I noticed after purchasing the Csi3 it states it is voiced matched for the Polk RTI series speakers. Will this make a difference using the monitor speakers with it instead of the Polk CS1? Thank you.
Post edited by raidical on
Yes they are not the same, you should get timbre matched speakers.....it's not a huge deal, since you have the chance to return I would and get the matching monitor....if you are the type to think what if way down the line....then change it now
Willow,
Thanks for the info! I will return and exchange and do this thing the right way..Take care.
