Rattle in speaker cabinet
Skizix
Skizix Posts: 3
edited December 2004 in Troubleshooting
When I recently moved my CS400 center speaker, it tilted and sounded like a part had broken loose and was rattling around inside.
The speaker is still under warranty so I am leary of attempting any work myself.
What does Polk recommend?
Many thanks!
Post edited by Skizix on
  • PolkThug
    PolkThug Posts: 7,532
    edited November 2004
    Personally, I would unscrew the speaker terminal and dump out the 'rattle'. This operation shouldn't take more than 5 minutes.
    Regards,
    PolkThug
  • michael_w
    michael_w Posts: 2,813
    Could it just be a wire inside that hit the side of the cabnet? What exactly do you mean it tilted?
    F1nut Posts: 50,841
    Unscrew one of the drivers, grab a flashlight and take a peek insdie.
  • Skizix
    Skizix Posts: 3
    Thanks for the replies. Polk responded and said the warranty is not voided so it's OK for me to open it up.
    By tilting, I titlted the speaker when carrying it. Sorry, I should have been clearer on that.
    This is getting interesting. Last night when I was putting the CS400 on my workbench I gave it a good tilt and for lack of a better explination, it sounds like a dozen beads of soder are loose inside.
    The speaker panel uses hex screws and wouldn't 'ya know it the size I need is missing from my set. Oh well, now I have a good excuse to buy a new set.
    I'll update this thread after I take a look inside. Hopefully tonight.
  • Airplay355
    Airplay355 Posts: 4,298
    i've had rattling inside my speakers before. polk is messy with the glue and its probably some loose glue rolling around in there. i pulled out a big chunk from my fxi30.
    good luck
  • Tour2ma
    Tour2ma Posts: 10,177
    Originally posted by Airplay355
    polk is messy with the glue ...
    Mexico was messy. One of the reasons production moved to China...
    More later,
    Tour...
    Vox Copuli
    VR3 Posts: 28,820
    Sounds like a bucking magnet may have come loose, maybe
  • Skizix
    Skizix Posts: 3
    Opened the speaker this morning and here's what I found: (drum roll please)
    82 Nestle Toll House Chocolate Morsels
    6 Sunflower seeds
    Enough bird seed to require vacuuming.
    :eek:
    I've had the system in my basement and it sure looks like some mice were making it their stash box. :confused: This is surprising as the cats have been vigilant with mouse control. They actually had morsels stuffed into the insulation! Note- I live "out in the sticks" and "visitors" are somewhat a way of life. . .which is where the cats come in.
    Problem solved. Faith in Polk speakers returned to 100%.:D
    Thanks to all who replied!
  • sowen010599
    sowen010599 Posts: 343
    ROFLMAO!!!!!!!!!!!
    Go BIG or go home!
  • PolkThug
    6 Sunflower seeds
    :eek:
    It would have to be mice at the factory it was assembled at, unless your missing hex wrench......
  • Tour2ma
    Are you sure those were chocolate chips??? :eek:
    Whole thing sounds to me like another strong case element for PR's over ports...
    More later,
    Tour...
    Vox Copuli
  • pmlewis
    pmlewis Posts: 100
    I heard a rattle in of the SDA 1C's I just pickup up. I took out the drivers and found a pioneer surround speaker up behind the tweeters. I new they were in rough shape, but I guess I freaked the kid out when I said I wanted to hear them. I just wish he didn't damaged two of the surrounds and cut the termials off the wires to hook it up. I just love Ebay!
    VR3 Posts: 28,820
    I got a feeling the mouse made its way through the port...
    I feel sorry for you SVS owners with the gigantic 3" ports ;) - I dunno, a 10hz test tone at reference level would solve that though...haha
