Need a new Univeral Remote Control!
hamzahsh
Hi folks, I'm interested in buying a new universal Remote Control (URC). Any recommendations. I'm planning to get a Hometheater Master MX-500 URC. I've also read the detailed review on it. I love it because it does everything that I'm looking for. If you know any other brand/model then please tell me.
I'll be buying it online, so let me know where to get one!
Thx!:)
Thx!:)
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
NAD C272 (2-ch Amp)
Post edited by hamzahsh on
I asked the same question a couple of weeks ago in this thtread:
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=23081
The first two(Sony) do well with simple systems.
For complicated systems, I would still go with the Harmony 768.
You can find it for $150 or less if you look. I found it on overstock.com for around $120.
Hope this helpsTschüss
Zach -
The MX-500 is an excellent remote. I have one. But for the price and value today, I'd go with Harmony.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
www.remotecentral.com
everything you need is thereBrian Knauss
ex-Electrical Engineer for Polk -
I'd take a look at the Harmony 680 and 676. I have the 659, but I think the placement of the DVD/VCR/DVR buttons are more convienent on the next two models up.
Taking a quick look at the remote you are considering it looks like the difference is that the Harmony doesn't have quite as many customizable buttons listed on the LCD. It is, however, probably a hell of a lot easier to program the way you want it.Just... Bonham
Hitachi 52" Rear Proj' HDTV: 51XWX20B
Comcast Motorola HD/DVR Cable Box; DCT6214/2005
Sony Prog' Scan DVD; NS752P
Harman Kardon AVR 7300 Receiver
Harmony 659 Universal Remote
Polk Monitor 70 Front Mains
Polk CS2 Center
Polk PSW12 Sub
Polk FXi3 Surrounds -
I've seen harmony remotes. They look more ediot-proof and simple to use, I like HT MX-500 it looks more advance and professional especially when you own separates, you know what I mean!;) . It has a really good backlit on the buttons in the dark. There is also a joystick type button for navigation which is an excellent feature on it. The battery cover is much better also.
I'll go with the HT MX-500. I found it on www.amazon.com for $69.99 but there is no international shipping available for it. I live in Canada and www.amazon.ca doesn't carry it. TOO BAD!
Where I can buy it?Panasonic TH-50PX80U Plasma HDTV
NAD C272 (2-ch Amp)
Malata DVP-580 (Multi-region DVD player) -
I suggest going with the Mx700 or the mx800. Much better remotes and the 800 has RF.Dan
