Vac-u-Vin Your Dimpled tweeters away...
Tour2ma
Tour2ma Posts: 10,177
edited November 2004 in Troubleshooting
The tweeter on my original CS400 got dimpled somewhere along the road of life. I've read all the "tape/ sticky stuff on the end of a pencil" approaches, but thought there had to be something better...
Tonite I was putting away a couple wine glasses and spyed my trusty Vac-u-Vin and went hummmmm...
Turns out the Little Sucker (pun intended) is a perfect fit on the rim of the standard Polk tweeter's dome...
Before...
More later,
Tour...
Vox Copuli
Post edited by Tour2ma on
  • Tour2ma
    ... and after...
    Not perfect, but not bad either... may try a little tape follow up, but really is acceptable as it is...
    And it's great for saving opened bottles of wine... available at Amazon.com...
    More later,
    Tour...
    Vox Copuli
    VR3 Posts: 29,401
    I am pretty sure about this...
    If you remove the RTi tweeter from the baffle (I posted a thread about how to do this in troubleshooting) ---
    And twist off the magnet, you will have access to the dome... ;) (If I remember correctly)
    That is pretty cool though....
  • shack
    shack Posts: 11,154
    Tour - after seeing that tweeter, it sure doesn't look like the SL5500 we discussed in an earlier thread. Did you happen to pull it out and look.
  • Tour2ma
    Sure didn't...
    And now no need to as the dimple is fixed (at least as far as I am concerned) and the newbie with the RT400's bought current stock CSi and FXi models...
    More later,
    Tour...
    Vox Copuli
  • amulford
    amulford Posts: 5,020
    You got rid of the dimple, which was cute.
    Now it's got a nipple, and it's sexy ;)
  • Eric W
    Eric W Posts: 556
    You're correct on this for the previous Rti generation you could access the back of the dome this way. Most dome tweeters are sealed from the rear however.
    -Eric
    -Polk Audio
