Newbie just looking for tips
Oxygen_man
Oxygen_man Posts: 2
edited October 2004 in Troubleshooting
I have recently just started piecing together my home system. This has been a dream of mine for a while, but I have never really done extensive research. I own a JVC receiver with R50 towers, R15 surrounds, CSI3 center and PSW202 sub. I live in an apartment with just one way to configure my living room. I am getting little to none rear sound from my R15's and I am looking to fix this. Oh, Please dont laugh at my receiver. Im just starting and I thought quality speakers first would be better then buying an Onkyo straight out of the gate. Any insider tips and hints would be appreciated.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited October 2004
    O2M,
    First, welcome to the Club... We're gentle for the first 5 or 10 posts (or so)... Unless post one is someone promoting their ebay auction for Polk speakers we'd all kill to own... YOu did not do that, so you're off to a good start.
    Give us the model number of your JVC and we'll see what we can do... Hopefully it's just a calibration issue.
    More later,
    Tour...
    Vox Copuli
  • Airplay355
    Airplay355 Posts: 4,298
    edited October 2004
    what are u watching/listening to and what surround mode are you using? how do you have ur dvd player hooked up to your receiver?
  • HBombToo
    HBombToo Posts: 5,256
    edited October 2004
    Help us understand how you have your cd/dvd player connected? Are you using TOSLink or analog out of your player to your JVC??
    HBomb
    ***WAREMTAE***
  • Oxygen_man
    Oxygen_man Posts: 2
    edited October 2004
    I am working with a JVC 6040-B. I am using a digital fiber-op connection for my DVD player. Now, I am new so I apologize for my ignorance, but is TOSLink another name for all that I just said? Also, the surround modes that I am referring to are any 5.1 Dolby Digital tracks that I have and/or DTS. I have set my center at 7, my front L and R at 3, my surrounds at 4, and my Sub at 5. I have my center set high because I am getting great FX sound but I have to crank the volume to hear dialogue. I am usually jumping back and forth between 15-20. I hope this helps you help me.
  • sowen010599
    sowen010599 Posts: 343
    edited October 2004
    Yes.
    You should also pick up an SPL meter from Radio Shack. Use it to set the level for your channels. Your receiver should have test tones built into it to help with this process. Consult the manual for more information.
    Go BIG or go home!
  • Tour2ma
    edited October 2004
    Waht he said... plus a calibration DVD ala Avia.
    Good, recent thread over here http://clubpolk.polkaudio.com/forum/showthread.php?s=&postid=224306#post224306 discussing calibration.
    More later,
    Tour...
    Vox Copuli
  • Airplay355
    edited October 2004
    double check your settings on your dvd player and your receiver just in case.
