my re8
neomagus00
Hmm... i've noticed a small issue with my new re8-enabled setup, namely that it hits late - to the point that I can feel the delay with my hand when i touch the sub. i haven't been able to find a low resistance air-wound inductor of the appropriate value for the xover i need to build (anyone know where to get one?) so i'm hacking my music in the following way - the sub is wired to the right channel, and the mains are wired to the left. every song i play is digitally redone such that the right channel is lowpassed at 80Hz, and the left highpassed at 80 (with some volume matching thrown in, and a little bit of eq). it's with a very good program, namely GoldWave, so i know that's not the problem; any reason that this should be happening? it shouldn't have anything to do with group delay, it's only a first-order system...
Post edited by neomagus00 on
what do you mean you can feel the delay?
no entiendo
when i stick my hand on the sub, i can hear the kick (the higher notes of it at least) from the mains, then a split second later i can feel the sub jump... there's a definite delay...It's not good, very fundamentally simply not good. - geolemon
do you have some type of delay on the HU?Music is like candy, you have to get rid of the rappers to enjoy it
ahh...and im not getting the re8 for $35 anymore...
im getting the 10 for the same price:D
Hey, honestly.. call every radioshack around and ask if they still have one of those 'optimus' sub coils... lemme look up the no. for you if you need... they'll cost $11 or something, and perfect for subs... I believe they are roughly 100Hz down for a 4ohm load, or 50Hz down for a 2ohm load..___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
jerry (i think) - i dont think they carry the coils any more, ive looked in several shops and online, and nothing like that exists...
cody - no hu, this is ht use ... but no, no delay, i checked it out... tis strange, no?It's not good, very fundamentally simply not good. - geolemon
has to be something with your reciever then no?
that's what i've been assuming, but it's never done anything like this in the past... this weekend i'm going to take it outside and see if some strange resonance in my room is causing me to think it's hitting late... i dunno if that's not it...It's not good, very fundamentally simply not good. - geolemon
Good to know that that's not in your car... I think I would end up driving in circles or something strange if I had it rigged like that...
And the Optimus coils will be hard to find, they are disco'd. Never hurts to call and ask. A lot of radioshacks will have them lying around in the back along with all the other components (speakers, subs, tweeters, etc) that are disco. Not even the managers know what they have back there.. believe me I've worked there...
If not, you can call RSU (radioshack unlimited) at '1-800-the-shack' and ask for a 40-1326 (High-power choke coil)
See this page for specs.
This is rated at 200w, but will handle a good bit more... i've run over 300 through them.. R/S also has a pre-built crossover network that handles about 100w, but I don't know the number for that.___________________________
BTW, "Optimus" brand at R/S: the passive components at radioshack are "realistik" brand, and the Active (receivers, etc) are made by "Pioneer"
So they are basically just b-models from good companies - good stuff.___________________________
cool, i'll look into it... so i've decided that maybe my box is at fault, cause it's not as perfectly fitted as I know i can make it, so i'm going to build a new one on sunday... a slightly bigger one to maybe take some boominess out, more bracing, sealing it right the first time... we shall see...It's not good, very fundamentally simply not good. - geolemon
I would think that increasing the volume would make the boominess worse, as it will lower the acoustic susension for the driver, and in turn it will have a less acurate response.___________________________
i'm hoping that it won't make it sloppy, but it's exceedingly tight right now, to the point that maybe the box is too small, causing boominess... i'm not gonna go crazy, maybe a 25% increase (it can't be any worse than my current box :rolleyes: ). plus i like getting it right, even the second time and the box is very small, so i have most of the sheet left over from this one, all i have to buy new is caulk & liquid nails...It's not good, very fundamentally simply not good. - geolemon
so, i built my box, and it is a bitchin piece of equipment, if i may say so myself. i should have pix by late tomorrow, but i haven't tested it yet - waiting for the sealant to dry... listening reports to follow...It's not good, very fundamentally simply not good. - geolemon
ill be getting me RE10 that i got for $35 sometime soon...i have no idea what im going to do with that...i sold the momo sub that i got from CC to a friend for the price i paid for it, found an amp for him on sale at CAF and its in his truck right now....good stuff
cool... well, properly installed, this little thing performs very well, especially considering it's an entry level 8"... only problem i've found is that it is very quiet... my mains are running at half again as much impedance as the sub, and they're at -20 dB relative to the sub right now (that's around 10% of the power going to the sub)... and this is with the whole setup in a fairly small, resonant environment...
btw, i noticed something strange with the new box - it's now quieter for a given volume input than with the smaller box... i thought larger boxes were supposed to be more efficient?It's not good, very fundamentally simply not good. - geolemon
Smaller boxes are louder.
More proof? Go to any review of a sub in Car Audio & Electronics. They list max db at 2 different box sizes and the smaller box is ALWAYS the loudest albeit not by a lot, usually 2-4 db.polkaudio sound quality competitor since 2005
huh... i would have figured the opposite, but evidence can't be wrong...It's not good, very fundamentally simply not good. - geolemon
This is some of the test results Im talking about:
Kenwood XW1300DVC (Dec 2003 issue)
.55 = 117 db
1.0 = 115 db
Orion H2 12.4 (The daddy) (Dec 2003)
.55 = 122
1.0 = 120
MB Quart PWE302 (Feb 2004)
.60 = 112
1.0 = 110
MA Audio 1200XL (Apr 2004)
.75 = 118
1.25 = 116
Pioneer TSSW12S4 (Nov 2004)
.65 = 111
1.0 = 109
JL Audio 12W6v2 (Mar 2004)
1.0 = 116
1.25 = 115
As you can see, the difference is very small but the smaller box is louder with the same power.
I love it when Im the only one thats right!polkaudio sound quality competitor since 2005
is this in car? or anechoic (sp?)? i think i understand why, at xmax, the smaller box is louder, but i'm trying to rationalize the larger box being louder at a given input voltage... but thanks for something to think aboutIt's not good, very fundamentally simply not good. - geolemon
From what I can tell, the output tests were done on indoors in a lab or something of the sort.
On a side note, the Orion H2 article had a graph for the BL curve in both the .55 and 1.0 box and the curve for the .55 box is drastically flatter than in the larger box.polkaudio sound quality competitor since 2005
when building sub boxes, you dont want a straight line...the lower frequencies will be louder than the higher freqencies
though i've never seen a bl curve, i am imagining it as being high on the left and then decreasing as frequency increases? or is it the other way round? and, you generally want a rolloff below a certain frequency, but that frequency depends upon the vehicle; at the extreme end of the spectrum, if we're talking about a convertible, we'd want a perfectly flat SPL curve... which brings up the question of how the bl curve relates to the spl curve in a given car and in an anechoic environment...It's not good, very fundamentally simply not good. - geolemon
in car---you want your frequency response to go down the lower the frequency you go...the natural effect of cabin gain will level it off
yep; now the question is how the bl curve in-car relates to the frequency response curve, also in-car (which will vary slightly vehicle-to-vehicle, but that's not particularly important here)
BIG EDIT: see the 'divided boxes' thread, but to solve the problem... mac, are those maximum spl's or spl with the same input power? for the same sub in a differently-sized box?It's not good, very fundamentally simply not good. - geolemon
for what he said to be correct it's going to be spl with the same input power, keeping all else the same (signal, power etc...) a smaller box will be louder than a larger box...
btw, excuse me while i admit my ignorance but wtf does anechoic mean??? i'm guessin it's a fancy way of saying in car... but as i'm sure i'm not the only unfamiliar with it i'm gonna be blunt and askMacLeod: I guess youre lucky Polk has such lax hiring standards.
Josh: Damn skippy! -
sorry i didnt define - anechoic means no reflections from a car or room or whatever and thus is the true unadulterated measurement of a sub/box system's response; usually this is approximated by a specially designed room that disperses the waves coming out of the sub so that you get extremely accurate measurements of the actual frequency response, without cabin gain or any such thing.
and, now that i read it again, he said maximum spl... i would assume that means xmax or pmax (maximum thermal power for the sub)... so it could very well be that the smaller box is louder at splmax, but only with more power... thus the larger box is indeed more efficient... mac, some clarification?It's not good, very fundamentally simply not good. - geolemon
First, the BL curve has nothing to do with frequency response. The BL curve shows the motor strength of the sub as it moves in boths directions. It shows how symetrical the magnet and mechanical systems are to each other. The more symetrical, the less distortion.
Second, from what I can tell from the articles, the same amps are used for each box.polkaudio sound quality competitor since 2005
okay, so a bl curve is a relation of field strength to excursion, then? and has nothing to do with frequency?
ADD: okay, i just finished reading CA&E's W6v2-D4 test, and here are the relevant numbers:
1.00 ft^3: SPLmax = 116.5; Voltage = 100
1.25 ft^3: SPLmax = 115; Voltage = 90
while i'm not positive on the exact sensitivity calculation, because it's logarithmic, it seems obvious that the larger box is more efficientIt's not good, very fundamentally simply not good. - geolemon
Thats my understanding.
Disclaimer:
I have no education in electronics or physics. I read car audio magazines religiously and read other publications on the net and other forums and everything Im spouting is my interpretation of what Ive read so dont take me as an authority!polkaudio sound quality competitor since 2005
