subwoofer wire
bkfk
bkfk Posts: 44
I currently have a single wire (with RCA connectors) running from my sub to the receiver.I now need to move the sub and run a wire through the ceiling/wall about 50-60 feet away.What kind of wire do I need to buy and does anyone know good places to get it?Thanks in advance for your help.
Post edited by bkfk on
  • amulford
    amulford Posts: 5,020
    edited September 2004
    I bought a couple of 35 ft runs from here at a reasonable price. They seem to be doing the trick..
    Blue Jeans Cable
  • Tour2ma
    Tour2ma Posts: 10,177
    You can also make your own if cost is a real concern and you are comfortable soldering.
    Belden coax and RCA terminations are available at most RS's and electronics stores.
    More later,
    Tour...
    Vox Copuli
  • mantis
    mantis Posts: 17,637
    if coax is going to be used then use a F connect then a F to RCA adapter.
    Dan
  • goingganzo
    goingganzo Posts: 2,793
    i can buld you a cabble i have all the stuff to make a canare one. i am using a 40 foot one on my ht and a 30 on my parents one. i can derss it up if you want that. i will make it for cost +shiping
  • bkfk
    bkfk Posts: 44
    Thanks for all the feedback and GOINGGANZO Thanks for the offer.I think a friend of mine is going to give me his if he finalizes plans to redo his entire HT room.If it doesn't work out I would like to come back at you for the offer if that would be okay.
  • goingganzo
    no problem just here to help ps i have invested about 100 in tools to make my cables so i will hook others up if i can.
