what to expect between 2 diff amp amounts
Willow
Willow Posts: 11,060
edited September 2004 in Electronics
if receiver A is 270W (amps) and B is 400W (amps) waht difference will this make ??
Post edited by Willow on
    F1nut Posts: 50,761
    Which brands and models are you asking about?
  • nemos2
    nemos2 Posts: 111
    Willow,
    Provided the amps are of the same quality, the sound difference would not be that big. If I remeber correctly, a 3db increase in sound means you have to have a doubling of amp wattage. So...in this case you would gain a 1db or so increase with the 400 watt amp, provided the amps are of the same quality.
    Others might mention more headroom etc....
    what are you looking at?
    Polk LSi 15 Fronts
    Polk LSi C center
    Polk LSiFX Surrounds
    Outlaw Audio 990 Pre/Pro
    Outlaw Audio 755 amp
    Paradigm PDR-12 Sub
    Outlaw Audio Cables
    BetterCables Cables
  • Willow
    I was just curious that is all but thanks for all the info
  • madmax
    madmax Posts: 12,434
    My tube amps have a switch which doubles the power. 50 watts to 100 watts. The difference is a slight volume increase. I think you need 4 times the power to double the output.
    Vinyl, the final frontier...
  • Tour2ma
    Tour2ma Posts: 10,177
    max,
    It's double the power per 3 db increase (which is double the output).
    What most ears preceive as double the volume is more on the order of 10 db.
    More later,
    Tour...
    Vox Copuli
  • madmax
    That is all good but saying "double the output" will lead him to think it is twice as loud.
    madmax
  • Polkfan
    Polkfan Posts: 15
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Output power is only one of many performance parameters that must be evaluated when choosing a receiver or an amplifier. More watts does not automatically equate to "better" sound, particularly if the higher watts come with higher distortion.
    In the case of receivers, manufacturers sometimes cut costs on the power amp section in order to include more features in the preamp/processing section.
    Internal parts quality and the ability of the amplifer or receiver to drive low impedance loads are also factors to be considered.
    It all comes down to what sonic results you are trying to achieve and what speakers you are going to be using.
  • Tour2ma
    Sorry, raife, I just can't get used to your DarqueKnight, handle...
    More later,
    Tour...
    Vox Copuli
  • DarqueKnight
    I wanted a brand new handle to go with the brand new and improved forum.:)
  • Tour2ma
    :D:D:D:D ... That got four...
    More later,
    Tour...
    Vox Copuli
