Static from rti10's?
coolfishy101
coolfishy101 Posts: 42
edited September 2004 in Troubleshooting
Lately I have been hearing static coming from my left speaker. Kinda sounds like crackling mostly when there is a lot of midrange playing.
I know it is not my speakers, because if I switch them the same thing happens to the left side. It seems to only happen while watching cable tv (it sounds fine with dvd). Also the left side seems to be twice as loud as the right. It is much more noticable when loudness is on (a function on pioneer receivers). This is a 99.9% home theater system.
Receiver-pioneer vsx-d411
mains-rti10's
center-csi3
rears-rt15i's
Is my receiver even capable of driving these speakers properly? I already have another thread going on about which receiver is a good choice for an upgrade.
thanks in advance
pioneer vsx-d411
rti10's
csi3
rt15i's
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    Thanks for using the Forum. I had a similar problem with my cable reception, noise in one channel. The best thing to do is have the cable supplier exchange the cable converter box. They usually do it right over the counter, I was forunate our Comcast is the building right beside us.
    Regards, Ken
  • coolfishy101
    Ok I guess I'll have to tell my dad to switch it out. ty for the help
    pioneer vsx-d411
    rti10's
    csi3
    rt15i's
