are they considered bright
right I understand, it's just so hard to know without doing hrs and hrs of research and even then what componenets are built with good parts !!
Whatever sounds best to YOU is all that matters! One man's brightness is another man's perfect sound. Only YOU can decide if you like the stuff or not!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
It seems audio does boil down to that in all aspects -
Exactly. Remember, audio is about enjoyment, not Right or Wrong.
If you really want to be picky, every component ever made and used in every system is WRONG, because NO system, regardless of components used, will sound EXACTLY like the original performance. So, no component can ever be "right".
But, all that doesn't matter one bit, if you enjoy the sound of your system, and gain enjoyment from the music or movies you play thru it.Bob Mayo, on the keyboards. Bob Mayo. -
Very well put GM.... !!!
