Sl1000
read-alot
Just peeked inside my CRS to make sure everything stayed intact after the cross country trip. I expected to see the pair of sl2000
that parts shows as the tweeters but I found a pair of 1000's. The date on the 6503s and the 1000s shows Dec 12 1984 and they look to be original. Are the 2000's or 2000t's replacements for the 1000's ?
polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2
Post edited by read-alot on
The new SL2000 replacement tweeter (the SL2000T- Polk part number RD0194-1) is listed as an equivalent replacement for both the SL1000 and SL2000 tweeters. This implies that the SL2000 can also be used as a replacement for the SL1000.Proud and loyal citizen of the Digital Domain and Solid State Country!
Thank You. I had planned on doing what you have done in the past and use these as a center. You have the most impressive use of SDA speakers and I respect your opinions as I read-alot.polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
The sl-1000 and sl2000 are different size. frame is different.Joey Ward
