PSW 303 Popping
zinktah
I have a Yamaha HTR 5660 receiver with RM6700 and a PSW 303. I bought the system in January and haven't had the problem until recently. if you are familiar with the Yamaha receiver, I had the volume at -30, about 1/4 of the actual capability. Keep in mind, this is pretty loud, but not loud enough to blow the subwoofer. I had an audio cable directly from the receiver to the subwoofer LFE unfiltered and I just switched it to the recommended solution with RM speakers of running the front speakers thru the subwoofer and setting the front LR to large. Still popping. Am I asking too much of this subwoofer or is there something I can do? I read a bunch of messages hear about popping but that seems to be the PSW 202 instead of the 303. Any help would be mucho appreciado.
Thanks.
Thanks.
Post edited by zinktah on
Hello,
Thanks for posting on the Forum. Can you please tell me where you have the volume set on the back of the sub-woofer? Do you have the knob set at 10:00 o'clock or 2:00 o'clock, for example?
Regards, Ken -
I am in need of the same assistance here; O.P, did you ever figure out what the problem was? I posted my EXACT dilemma in a new thread in this section of the forum.
