Magnifi-X sub will not fully power on
gmcman
This soundbar/sub is from July 2016, the soundbar powers on, music flows from a 3.5mm jack into the soundbar, but when you turn on the sub, the led quickly blinks once then turns off.
There is no sync button on the sub, just the soundbar.
With the circuit board plugged in, I have 24V leaving the power board into the 2nd board. Curious as to what I can test.
Your jump shot into the garbage can....Curious as to what I can test.
Lol...well, for the interest in diagnosing, I would like to see if my son and I can try to figure out what went bad. This is only being used as a PC speaker, we have options in mind if it needs to be tossed.
The brief LED flash suggests the subwoofer starts but shuts down due to a possible internal fault. Even with 24V present, the voltage may drop under load. A technician should inspect the regulators, capacitors, and amplifier board. This is a hardware issue, unrelated to online services like dollartree compass login.
Check whether the 24V supply remains stable when switching on the subwoofer. If the voltage drops, the power board may be faulty or the second board may have a short. If it stays stable, inspect the amplifier IC, capacitors, and voltage regulators for faults. For more troubleshooting guides, you can also visit dgmeportal com.
