Advice requested on next move
I’m asking for a friend, he has a Marantz PM-10 integrated amp, PS Audio Gain DAC, a Wiim Pro Plus streamer, and Dahlquist DQ-30i floorstanders. His cabling is decent. He would like to take a step up in his audio journey and wanted to ask what y’all thought would be best bang for buck improvement with a budget of maybe 3-5K. I never got into streaming so my opinion don’t mean diddley squat. Streaming is about all he does now. If he replaced the Wiim with something better what would y’all suggest that would up his game noticeably? Any other thoughts? Thanks in advance.
    VR3 Posts: 29,756
    the streamer, 99% of the performance is the power supply, IMO.
    treitz3 Posts: 20,366
    Get an R2R DAC. ANK or Abbas would work just fine IME.
  • Butter
    Butter Posts: 66
    I just recently bought a used eversolo dmp A-6 with an upgraded power supply. I love it! Its very versatile for me! I'm a limited budget guy so for less than $600, I'm golden! They now offer Dmp -A6 and Dmp -A8 Gen-2 and master edition. Linear power supply more inputs, yada yada yada. Some really great choices on the market!
  • dromunds
    dromunds Posts: 10,175
    VR3 wrote: »
    Do you have any specific suggestions for a significantly upgraded power supply for that Wiim?
  • ptrooper
    ptrooper Posts: 800
    edited September 10
    I recall Vr3 mentioning a Linear power supply giving great sound (no switching distortion) in a post somewhere .
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
    He has used no name LPS's, as well as an Sbooster. He has also used others, but the Sbooster is probably the one you are thinking of. A good LPS can definitely increase the sonics of a unit, especially when coming from a SMPS wall wart.
    heiney9 Posts: 25,714
    Not a lot of information to go on.
    A linear PS for the Wiim is a must. Not that familiar with the PS Audio, it gets great reviews. I'd say perhaps speaker upgrade, but that's a BIG category to try and navigate.
    I am unfamiliar with his speakers.
  • ptrooper
    ptrooper Posts: 800
    I believe the streamer would be a bottleneck with a LPS,I believe @treitz3 comment regarding a DAC would be a better investment in the long run.
  • dromunds
    Thanks fellas. His speakers are pretty nice. Image and sound stage like a mother. I have no experience with linear power supplies, which is why I was asking for specifics. The PS Audio Stellar DAC sounds good to my ears, and was a jaw-dropping improvement over the Wiim’s internal DAC, but I really have no experience with DAC’s, and I’ll pass on the suggestions to look at a R2R DAC.
    I believe Trey has one of those no name linear PS's still for sale in the classifieds. It's cheap enough to where you could at least get your ears on what it could do, and if he doesn't think the change is worth it, he could sell it for what he bought it for. Just food for thought.
  • marvda1
    marvda1 Posts: 4,972
    What does he think is lacking sound wise in his system?
    Puritan PSM156
  • dromunds
    I’m not so sure he thinks he is lacking sound wise, it’s that he wants to make a noticeable step up - and would like to know what his weakest link is. For the purposes of our discussion, I think we can take his amp and speakers out of the equation, those are not his weakest link. I (perhaps naively) just assumed it would be his Wiim streamer, but I’ve been schooled to learn the power supply is perhaps where he should begin, and maybe even look at the DAC. Any other thoughts by s would be appreciated
    He might want to entertain the thought of a Snubway and Master Class A/C filter combo. That will benefit his entire system, and reveal more to the music than he already has. If his system already images well, he should yeild a very noticeable improvement, for not too much money spent.
    These are also compatible, as his system evolves, no matter what direction he decides to go in.
