Request for Polk DSW- 600 Schematic Diagram
​Im looking for the schematic diagram for a unit labeled DSW660 externally, but the internal board is marked DSW600 (200W) I need the DSW600 schematic specifically because the boards are different. Any help would be greatly appreciated.
    pitdogg2 Posts: 27,921
    edited March 25
    There's really no need to keep creating new threads. @SeleniumFalcon will reaf your response in the previous threads. Polk is well known for changing things on the fly.
    One thing you may not know is the glue they encased many of the boards with becomes very conductive with age. It has been known to cause a ton of problems. If yours has it, may be a good idea to remove as much as you can OR think about a new SW.
  • tipo
    tipo Posts: 8
    OK, thanks for the info
