I need advice on mounting Polk ES20 front and ES15 rear speakers in my new house.
I'm about to move into a new house with a 20x20 area. I've prewired the house to mount the speakers roughly 12-14 feet off the ground. I want to angle them down as well as be able to rotate them. Does anyone have any advice on how to safely accomplish them and with which type or brand of mount? Thanks!
Answers
    billbillw Posts: 7,987
    edited March 25
    That's awfully high for speakers to be mounted. At that height, maybe consider getting in wall or in ceiling? The problem with the ES speakers is the rounded bottom. Normally, I would suggest BT77 (https://www.btechavmounts.com/product-range/products/bt77) clamping wall mounts, but I don't think they would angle down enough to sound correct, and they might not grip the rounded bottom of the cabinet. You certainly don't want those falling from that height. Could cause serious injury and/or damage to other furnishings. Maybe Dan @mantis has some ideas?
  • mantis
    mantis Posts: 17,621
    JakeD wrote: »
    Hello Jake,
    Why oh Why did you prewire to 12-14 feet ? I assume you have 20 ft ceilings in this room? I don't recommend using any speaker at that height for a few reasons.
    1 - That is too high to get the proper surround effect.
    2 - If your room is 20 feet high , you just caused yourself an Echo Chamber. Sound waves are going to bounce all over the place and the louder you play it , the worse it's going to get.
    I really wish you would have consulted with a professional Installer before you made this decision.
    So IF these wires, you have to use, can you take some picture of the room and let me think about the next best way to make this work.
    Dan
    F1nut Posts: 52,219
    Smells like AI
    F1nut Posts: 52,219
    For clarity, I was referring to an AI bot that has now been removed.
    pitdogg2 Posts: 27,655
    It just boggles my mind they do not remove both posts.
