Polk SDA Drivers MW6510 and MW6511
jmardy
jmardy Posts: 27
I bought these on eBay a few months ago after poking a hole in the surround of one of my drivers. I ended up repariging the hole and don't need these any more.
They are in excellent shape. Resistance readings are good. They sound good when bench tested (free air). The sticky coating on the cones has attracted a layer of dust.
I have used Loctite Power Grab Express Heavy Duty Construction Adhesive to secure the magnets to the basket.
$50 each
Located in San Rafael, Ca. USA.
  • Unknown
  • jmardy
    jmardy Posts: 27
    edited March 24
    You should keep them, they are NOT getting easier to aquire. The second thing, the powergrab is in the wrong place. It should be on top and right below the magnet. Where you put it is the only place it cannot move due to the rivets used to connect the basket to the magnet/ voice coil structure.
    Good idea. I guess I'll find a place for them.
    Confused about where to put the powergrab. Is it between the black magnet and the steel top?
  • Unknown
    edited March 24
  • jmardy
    jmardy Posts: 27
    Many thanks @pitdogg2 !
    Not sure how I was so far off! :smile:
