Mitsubishi LT-30 Linear Arm Turntable
SCompRacer
A forum member dropped this off a while back. I'm sure Jay will chime in and like the seagulls in Finding Nemo, say "mine!, mine!, mine!"
"This Mitsubishi LT-30 is a real beauty with original box, packing and dust cover. Figured I'm on a roll fixing, maybe I'll get lucky again.
The tonearm is reported to be misbehaving. But like that Marantz Carl gave me to repair, a car ride seems to have fixed it. But we'll see...it may need a 494 mile car ride.
I assured my Mitsubishi LT-5V that it is not being replaced as it is not mine and wouldn't fit on the shelf anyway, so please don't act up....
1st dibs if it’s for saleThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
OK I got you down, but as second dibs.....
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Burnnn....
Ooh, pretty turntable!
Thanks to Rich for being willing to admit it to his queue. I'm grateful to have a friend so capable and generous to take a look under the hood.
Following this thread with interest.
Jay
Jay, we should invade Richie's space some Saturday, maybe get that A-ron guy in on it as well😉😁
Should we invite Rich?
Jay
If he can make it....
You just need to get the key fob for turning the turntable air pump on. Otherwise, it's a trip into basement.
Two belts ordered from TurntableNeedles.com. Seems to be popular with some of the Mitsubishi guys. They had both the 3.5 and 5.1 square belts while some places just offered one.
https://www.turntableneedles.com/Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I use to have an LT-5 (I think that was the model) and wish I'd never let it go.--Gary--
So Jay @agfrost stopped over to drop off some headshells/cartridges and visit the patient. He sees this and says, "They do exist!"
I've had to replace bulbs and speed LED's in my LT-5V. I replaced the tonearm bulbs with LED's. I used resistors to dim them and keep the current below max so they last. The vertical TT fits nicely on the shelf for my workbench system.
LT-5V
I found one of these cutaway drawings for the LT-5V. Maybe one exists for the LT-30.
SCompRacer wrote: »I found one of these cutaway drawings for the LT-5V. Maybe one exists for the LT-30.
If you take a reciprocating saw to mine, you can generate your own cutaway drawing! Oh wait...
Was cool to see you have the Mitsu overhang gauge 50. Never thought I'd see one in the flesh plastic!Jay
Belts arrived. Scary time, no collateral damage allowed. It's both fun and stressful. @agfrost
The easiest belt to change.
Underside. The downloaded SM is hard to read. Difficult to see exactly what they speak about removing.
I read all the bulbs were all supposed to illuminate with power on. Third bulb is good, no power to it, even when tonearm advanced to end of LP. Have to crack the manual.
Lots of parts to document removal of.
The plate has to come off. The plastic end of spring was just pressed onto a stud.
More to come...
Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SO that's where the screws are for the tonearm shaft.
Just slide it to one side then snug the set screw.
This is the downloaded SM I have to work with. No biggie, we'll figure it out.
Now we can get the tonearm out. Can't go far with the wires attached. And there is belt # 2 for the tonearm lift.
Two of the problems with this LT-30, the tonearm wouldn't raise high enough to clear the LP and the tonearm height adjustment didn't work properly. To further disassemble tonearm, one must remove the cartridge mute switch....
and desolder the tonearm wires. The white gear has to be removed along with a C clip for the tonearm shaft. It helps to turn the height adjustment to remove the tonearm. The mute switch will get cleaned with DeOxit and flushed with iso.
The tonearm height adjustment was an easy fix. One screw wasn't real tight for the bracket with the gear that raises and lowers the tonearm and it swung away from tonearm. You can tell by the screws at edge of bracket.
More photocells and bulbs, and they work.
The gears had some wear from stripping but once the bracket was moved toward the tonearm post and the screw tightened with a JIS (Japanese Industrial Standard) screwdriver, all is well. Tonearm moves up and down like it was designed. Taking a break now.
https://youtu.be/kJmZAo7V0OI?si=gBVgR9U-uRhewPyj
You make it look easy! It's a beautiful table! Add me to the dibs list
Carl -
Wow, Rich--You've had a busy/productive Saturday!Jay
First bulb is end, second light is for 30CM or 12" vinyl, third light is for 17CM or 7" records. Next time I light it up I'll stick a 45 on it to check. The size light source at left rear corner shines a light and holes in the matt/platter line up with photocells. I should have known that since my LT-5V uses the same record size system.
The stylus height adjustment didn't work either. The shaft was frozen, almost like someone glued it. It doesn't allow for more than an 1/8" movement but it moves now. A small screw engages the groove in shaft to secure it.
A screw, not shown, tops it off to adjust.
The gear/cam goes on the bottom of that shaft. The other shiny thing is the tone arm cue and it rides on the gear/cam. They use a damping fluid as lubricant, so it lowers slowly. Tape decks sometimes use damping fluid as lube on the left tension arm for slow take-up.
The karma
, I mean dibs list has been updated.
They are my go-to for ALL belts, and they have a decent rewards program. I particular like how they disclose all the belt dimensions in detail.SCompRacer wrote: »Two belts ordered from TurntableNeedles.com. Seems to be popular with some of the Mitsubishi guys. They had both the 3.5 and 5.1 square belts while some places just offered one.
https://www.turntableneedles.com/"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Jay already had bulbs from Bulb Town, so best practice is to replace them while the tables apart. Especially the two inside the tonearm. Deck takes sixteen 7219 12v along with two 680 5v for the record size bulbs. The control panel takes 11 bulbs. Sadly Bulb Town closed September 12.
Bulbs were tested before and after install with my Fluke PM2811. All harness's unplugged from board so no back feed issues.
I've seen pics where guys tear or cut the glued rubber block off the PCB. After desoldering with the Hakko, I was able to knock them out easy.
This is how I found the wiring in the tonearm. That is not the factory way.
This is how it's supposed to be. The SM pic was pretty bad but someone took a nice pic of how to do it. My cell died but I kept on going. The mute switch was cleaned with DeOxit and flushed with 99% iso. The after-Ohm test was better than the before.
A little glue holds the wires in the photocell bracket that bolts to bottom of tonearm. Previous repair used tape so the photocell bracket wasn't lying flat. You have to insert tonearm wiring into the open square then attach it to bottom of tonearm without pinching any wires. Some wires were flattened from previous repair work, but not broken, insulation intact. I found it easier to route wiring and attach the photocell with arm not installed in deck.
I
Jay
This is a snagged pic of an LT-30 lamp holder for the control panel. Jay's was in nicer shape. Way easier to do bulbs on a PCB. Those plastic blocks in the tonearm, stay too long with the solder iron and the connection pins melt the plastic and fall out.
The inside of the base has some protective lining loose. The wiring to tonearm can rub against it as it traverses. A little contact cement, some tape applied in case it oozes out. That second scope I snagged and need to fix provides some weight on a board to keep it flat. Have to do the rest after it dries.
Jay has an Elac 896H 24 Sp mounted on the headshell. We'll have to view the stylus on a USB microscope later. Internet says 1.25-1.75g tracking force and 300pf load capacitance. I get 79pf from tonearm to RCA block and ~155pf for the RCA interconnects for ~234pf.
There was a thread where someone claimed headshell to RCA block was 243pf and the RCA cables were 67pf (310pf total), but my Sencore Z meter didn't agree. They also replaced the mini coax from mute switch to RCA block with Cardas tonearm wire. I would think that would increase chances of RFI noise as it is not shielded. Mitsubishi used a long run of mini coax (~25") to keep from stressing the cables/wiring as the tonearm (and wiring attached to it) moved across the record. I don't even have strippers small enough for those.
I'm a call this a wrap. Jay needs to skip school and pick it up.
Beautiful work and documenting all the work. I always enjoy seeing how much is needed to repair or refurbish old gear. ThanksMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
An overdue update. Back in Sept 2025, I tried the LT-30 one more time before Jay picked it up and it acted up. Sometimes it would play fine, tonearm would traverse normally. Sometimes it would hang and skip. If I lifted the tonearm and moved it simulating the stylus following the groove, the tonearm would traverse in the direction I moved arm. I tried diagnosing the problem and failed to find it. I ended up getting frustrated and left it sit. In a post I made at Tapeheads, someone mentioned it could be the horizontal motor.
I had tested the horizontal motor on a bench power supply, and it seemed to work normally. By hand it would spin easily. Power to the horizontal motor is controlled by two bulbs/photocells in the tonearm. When diagnosing the problem and today, I monitored the voltage to the horizontal motor and used a mirror to observe pulley movement. I had made some black lines on the white pulley to detect movement.
The voltage fed to the horizontal motor varies from .450vdc to a little over a 1vdc. The paddle and lights/photocells in tonearm determine how much voltage is sent to motor based on stylus tracking, how far the arm swings. What I didn’t do in my previous testing with the bench power supply was keep turning the motor on and off at a low voltage, like .450. Sure enough, the motor would stop at one point and would not turn with .450v supplied to it. If I bumped it up to 1v, it would turn.
Schools out and Jay had an LT-20 we could use as a motor donor so he stopped by today. We swapped motors and played the LT-30 for almost three hours. We turned it off, then back on. No failures so he went home with it. I hope I didn’t jinx us and he calls me tonight and says it still works.
The organ donor...the LT-20 has the vertical tonearm lift motor under the table while they used a smaller motor inside the tonearm of the LT-30.
The horizontal motor in the LT-30 sits in a rubber block.
I hope I won't have to have mods edit this post and show a sad Jay....
And he got to hear some R2R.
I forgot I made this shipping bracket screw saver last year. Today I dropped that tricky to get in and out screw into the slot that leads to inside, had to remove the baseplate to retrieve it.
The LT-30 has made it back to my place and is continuing to perform flawlessly. 🤞
When I dropped this off at Rich's, I didn't intend for the puzzle it presented to be so difficult to solve... Like a car with an intermittent fault, this would've been simpler, perhaps, if it had a clear failure, but it kind of, almost worked!
Anyway, as anyone who has followed his build and repair threads has seen, Rich is a pitbull when battling a problem and he'd gotten at least a "best guess" as to what might be the fault--and it appears the motor swap has done the trick. It was somewhere in between comical and painful watching him as it was spinning vinyl on his test bench earlier this afternoon (see photo above)--He had the look of a man waiting for the other shoe to drop and for the tonearm to hang up yet again--I shudder to think of how many hours of grief this repair caused him. At least he's had the "simplicity" of reel-to-reel refurbing to turn to. 😂
So once again, Rich, thanks for your time and talents. As always you've been a generous friend and host; you've done a lot to help me along in my journey with audio in the years I've known you.
Probably should include an action shot, so here it is in situ spinning vinyl this evening at my place. And yes, below it is the Krell KSL I picked up from Rich several years ago, after he'd recapped it with typical care.
Jay
Well Jay, he's retired and needs something to keep his mind nimble.
Don't want him rusting in place
