SDA 2.3 with donuts
There is a pair of SDA 2.3 speakers for sale but they have the speakers with the donuts. They are priced at $1000.
Should I steer clear of the models with the donuts?
Is this a good price?
Thanks for your opinions.
  • la2vegas
    la2vegas Posts: 775
    Steer clear...
    F1nut Posts: 52,406
    tom1263 wrote: »
    The SDA SRS 2.3 is the only model that uses the MW6513 donut drivers. I have those available.
    Price depends on a number of factors. Mint condition generally brings a higher
    price. Original boxes/packing material add more value. Location and availability factor into it as well. What might bring a certain price in one area will not in another. Keep in mind that sellers are usually open to negotiation.
    Simply stating steer clear in this case is bad advice.
  • tom1263
    Thanks for the advice! I would love to find some TL models, but haven't come across any. I'll try to see if a better price can be negotiated.
  • la2vegas
    la2vegas Posts: 775
    edited February 2025
    tom1263 wrote: »
    Where are you located?
  • tom1263
    tom1263 Posts: 6
  • tom1263
    I'm in Minnesota.
  • la2vegas
    la2vegas Posts: 775
    tom1263 wrote: »
    I'm in Minnesota.
    Ok. I was going to offer you a sweetheart deal on some 2.3TL's. 2p5jip7op4ic.jpg
  • aprazer402
    aprazer402 Posts: 3,466
    I bought my 2.3's with the donut drivers locally in 2010. I paid $700.00, they are near mint. I still use them. They are a fine sounding speaker, not a hard pass. But try some polite haggling.
  • tom1263
    la2vegas wrote: »
    tom1263 wrote: »
    I'm in Minnesota.
    Thanks for the thought. I’m guessing you’re in CA or Vegas, so that would be a bit far!
  • la2vegas
    la2vegas Posts: 775
    Yes, I'm in Southern California, and it would be really expensive to ship to Minnesota.
  • la2vegas
    la2vegas Posts: 775
    audioluvr Posts: 6,079
    That price seems really high if they are stock.
  • zachOne
    zachOne Posts: 1
    la2vegas wrote: »
    tom1263 wrote: »
    I'm in Minnesota.
    Was doing research on the 2.3 when I came across this post.
    You speakers look very clean and possibly upgraded. Would it be worth me trying to purchase them from you?
    Ups has shipping for $200 per speaker to where I leave
    Freight shipping have shipping cost for $700.
    Question. I’ve a denon amp that has 165wats per channel at 8 ohms. Is this good enough for the 2.3?
    Thanks for the help
  • DaveHo
    DaveHo Posts: 3,584
  • la2vegas
    la2vegas Posts: 775
    zachOne wrote: »
    la2vegas wrote: »
    tom1263 wrote: »
    I'm in Minnesota.
    Thanks for the help
    I'll send you a PM to discuss this further.
    F1nut Posts: 52,406
    UPS will destroy them.
